Screamin' Eagle stage 1 air kit
Old Dec 9, 2008 | 03:15 PM
ezriderpgh's Avatar
ezriderpgh
Default Screamin' Eagle stage 1 air kit
I installed the stage 1 kit today, took less than 1 1/2 hrs being careful. The instructions say to remove the fuel tank so that you can get to the button head screws that hold on the a/c bracket, but you don't need to remove the tank. I am running stock modified mufflers and xied's and it is running absolutely great.
Old Dec 9, 2008 | 03:21 PM
flashprez's Avatar
flashprez
What is a fuel take??? What ever it is I did not take it off mine.
Old Dec 9, 2008 | 03:26 PM
lmb1485's Avatar
lmb1485
got the same thing with no problems
Old Dec 9, 2008 | 03:31 PM
ezriderpgh's Avatar
ezriderpgh
sorry, i meant TANK. that'll teach me to proofread!
Old Dec 9, 2008 | 08:20 PM
HD-EZ2NV's Avatar
HD-EZ2NV
WHAT!!! AAArgh!!!
I'm doing this right now and thought I had to remove the tank. Where were you guys yesterday when I could have used this useful tidbit of information! Would have saved me a ton of time!
Old Dec 9, 2008 | 08:50 PM
Deepsouth251's Avatar
Deepsouth251
Originally Posted by HD-EZ2NV
WHAT!!! AAArgh!!!
My question is do you do away with the bracket and bolt the backplate directly into the cylinder head, if so how do you get to the bracket screws to take it off with the tank still on.
Old Dec 9, 2008 | 09:15 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
You can get to the bracket screws and remove the bracket without removing the tank, it is a tight fit but you can get them out. Keith here is the master at Stage 1 kits one the drive by wire bikes, he can install one in 10 minutes (not kidding) He gets alot of practice!
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
ms3300's Avatar
ms3300
How much was the kit itself. I have installed the Xied's and am thinking about putting just the stage 1 kit and running without the download...keep me posted on how she does.
Old Dec 10, 2008 | 05:23 AM
ezriderpgh's Avatar
ezriderpgh
You can get to them with an allen wrench or you can use a hex head socket type on a spinner. The bracket is disgarded. I put the screws back in with a nut for a spacer just for looks.
Old Dec 10, 2008 | 06:32 AM
roadking1893's Avatar
roadking1893
What's the major difference aside from physical appearance and able to accommodate a K&N filter designed for the kit. Is there a bore difference to let more air in?
