those chrome caps that go on the the end of chrome rails that hold a license plate on baggers after you cut them off? My dealer no longer has them.
I'm sorry, I haven't described these well, but I don't know what they're called. It's that round peice of chrome tube the license is bolted to and some cut that piece off when re-locating the plate below the tail light.
Marsh, the products referenced are used to replace the chrome support tube (which is Harley-speak for the part you refer to) after you remove it. Some guys cut the curved part off and use a chrome cap to cover the cut ends. Removing the tube is easy. If you see a bike with the HD Stealth luggage rack, the rack replaces the same tube--it's basically the tube with some luggage rack pieces welded on by HD.
yow! to use their end caps (10.95 ea), you have to use their grab bar eliminator kit (85.95). thats kinda pricey!!!!
i just went to lowe's and bought a set of hole plugs, they had them in chrome, or in black plastic. i bought the black plastic ones, 1.30 for 2.
i had cut my grab bar off at the very end of the strut cover, so it was not perfectly round, so i had to buy a size smaller than i really needed, but a dab of glue held it in just fine.
I did the same thing with the chrome plugs from Lowes. I cut them off long with a hacksaw,then trimmed them down with the lathe. You could do the same with a pipe cutter for a neater cut.
Reason: typo
