I went for a put the other day and upon my return i parked as usual in my driveway facing the garage door and put the bike on the center stand. Needless to say there is a small swail in the concrete driveway for water to run off, not the bike. After putting the bike on the center stand i got off and opened the trunk to get the garage door opener out and as i lifted the trunk the bike moved ever so slightly and the center stand FOLDED!! But quick thinking prevailed and i stayed calm and the bike stayed erect as i am holding on to the back of the passenger backrest. The bike just stayed perfectly still as i tried to grab the throttle, but guess what? I left the engine running, so i could not grab a hold of the throttle as i was afraid i would turn the throttle, so i grabed the switch housing instead. So far so good, but i am on the right side of the bike, not the left side that i am accustomed to mounting her. Very carefully i put my leg over and this story comes to an happy ending!!! I will not be doing that again. Be careful where you put the center stand up. LEVEL IS GOOD !!!
Center stand?? Mine just has the jiffy stand, but I'm glad you were able to avoid any damage, to your ride or yourself! I've had to wrestle my bike a couple of times, and threw my back out once doing it.
what is it with these jiffy stands i have parked mine a few times and could swear it's moving hasn't fell over yet but sure makes you think it's about to.
The jiffy stands are designed to move. There is a pin on the upper end. It engages a slot and that is what you see as movement, (yes they will "rock" a bit). The whole thing is spring loaded to pop the pin out when the weight is off the stand.
(I simplified it but if you take a look at the upper end of the jiffy stand, you'll understand)
