VDC Batteryminder
Old Dec 30, 2008 | 09:04 AM
LUBA's Avatar
LUBA
Default VDC Batteryminder
Does anyone use this charger? I have an issue with it. I have an 08 flhx with the stock battery. Which I believe is an AGM battery. This charger model#12248 has settings for 3 different types of batteries AGM, Flooded, and GEL. It also has 2,4 and 8 amp charging rates. I select AGM, and either 2 or 4 amp settings, and when I check the bike later it is always on the GEL and 2 amp setting- which BTW is the default setting. I thought it was losing power at the outlet so I switched to a different one and same thing happens. WTF? It states in the manual for the charger to select the right battery and charge rate for best results. Just wondering why this thing keeps switching on me. I also have the optional temp sensor hooked up and it is in my unheated garage which is in michigan.
__________________
Old Dec 30, 2008 | 11:36 AM
LUBA's Avatar
LUBA
Anyone?????????????
kris55
Electrical/Lighting/Alarm
Oct 25, 2017 06:50 AM
SgtMic
Audio Systems
Feb 10, 2017 06:26 PM
timmanis2000
May 19, 2011 04:36 PM
jlasoftail
Mar 17, 2011 01:33 PM
LUBA
Dec 30, 2008 09:02 AM
