Exhaust
Old Jan 2, 2009 | 06:56 AM
duglaura&flhti's Avatar
duglaura&flhti
Default Sounds good
Sound is so passive and to select the sound you want is passive too. Go out and ride with others....different applications on different sleds til you find a sound that match.....Everytime I do a poker run, I love hearing different exhaust and find the one I like.....Good luck....
Old Jan 2, 2009 | 03:41 PM
WADELL's Avatar
WADELL
Bought a set of factory HD modified cans off ebay. They sound great! didn't have to change any settings. More HP and performance.
Old Jan 2, 2009 | 04:22 PM
garyhendley's Avatar
garyhendley
i am running fullsac true duals and se mufflers performance and sound are great
ride safe
Old Jan 2, 2009 | 05:00 PM
jag1886's Avatar
jag1886
Performance is foremost to me followed by sound needs to have a nice growl and not be to loud, and last is looks. That is why I chose a Fat Cat, runs great isn't to load and it looks good.
Old Jan 2, 2009 | 07:57 PM
CrashX's Avatar
CrashX
Running a V&H pro-pipe, 2 into 1, has great sound. I constantly get compliments on the sound, not too loud, but does have a good bark when you get on it. The low end response is pretty good too.
Old Jan 3, 2009 | 12:34 AM
JohnScrip's Avatar
JohnScrip
Originally Posted by Twinrider
Well said! If you know some cans like that please recommend them.
Actually, I think I found the near-perfect solution.
It's going to sound stupid, so I'll attempt to be brief on an otherwise very long story...
(Insert very long story here) and then I finally wound up with a set of B&E Max 2's.
The Max 2's sound amazing - But they're quite loud.
(Insert another very long story here) and then I had this freakish idea - See, the B&E Max 2's are two different units -- The right muffler has a modified baffle and gives you the "clack-clack" sound, while the left muffler is sort of an open resonator.
So what I did was put my *stock* right side muffler on and the left (resonator) B&E Max 2 on.
Thrilled is an understatement - Pragmatically speaking. It's throaty and beefy enough (but not too much), loud enough when you twist it (but not so loud that you fear getting pulled over) and "rumbly" and crisp enough to be proud of your bike at a stop light.
One technicality I was concerned about - The normal 40%L / 60%R exhaust pressure was flopped about to probably 70%L / 30%R at idle (due to the almost open "resonator" of the Max 2 left muffler). I called my mechanic at the dealer and asked if it was going to be an issue (08 w/EFI) and he said that as long as it seems to be running well, it shouldn't be a problem. That concern vanished after a few tanks of gas when I realized that my rural mileage jumped from 42 to 47MPG... Two service calls (a 1k and a 5k) later and no complaints or notices from the mechanics.
Several kick-*** things here -- The B&E's are made from stock mufflers. The end on the Max 2's look completely stock (except I recall painting the end of either my stock muffler or the Max 2 with high-temp black paint to match the other one). If you wind up with certain officials that are writing people up without stock pipes, yours look stock. If they're writing up overly loud bikes, yours isn't unusually loud. And if you want to be rude for a weekend, it takes 10 minutes to put the right Max 2 on the bike.
Otherwise, you're getting a great sounding bike that non-bikers won't hate for $125.
The pleasant, low rumble at idle turns to an authoritative, slightly crispy, but just soft enough in the high end "bark" when that additional pressure builds with the throttle. It evens out perfectly on the highway so you can still "feel it" without making you crank up the stereo too much. And passengers can *talk* to me (SG with a 12" shield) without going hoarse.
All this begs the question - "Why didn't you just try the Max 1's" -- I did. That's part of one of those long stories above. Sounded like a Buick (it might have been louder than stock...) and had easily identified (visually) modified baffles. Two things I didn't want. And the Max 2's (as a set) were just too much. This was, IMO, a perfect compromise. And cheap. And looks 100% stock. And I think my "long story short" failed again...
Old Jan 3, 2009 | 01:47 AM
glens's Avatar
glens
But it was a good one.
Old Jan 3, 2009 | 02:25 AM
drrandall1's Avatar
drrandall1
Come on now. If you want performance get a crotch rocket. If you want women get a Harley with sound!!!!!!!!!!
Old Jan 3, 2009 | 05:45 AM
Jrsess's Avatar
Jrsess
As long as you like them that's what matters. Personally I wanted more sound.
Old Jan 3, 2009 | 06:17 AM
CSMHOG's Avatar
CSMHOG
+1, couldn't agree more. Our opinions don't matter cause our taste will be different than yours. Get out, ride and listen to the bikes!!
I for one, didn't like the V&H Ovals or Rhineharts but that's what most everyone else was getting. I went with Rush 2.0 slash ups. I love how they sound and perform!
