front end question
Old Jan 6, 2009 | 10:15 AM
shvlrydr's Avatar
shvlrydr
Default front end question
i am looking to convert my streetglide front end to a single disk setup and was wondering if anyone knows if say a set of lowers from a fatboy or heritage would fit? custom single sided lowers from a few companies are $400-$500 and i can get factory chrome single sided lowers for the other models for much less. just curious
thanks, dan
Old Jan 6, 2009 | 10:34 AM
REVHAPPY's Avatar
REVHAPPY
Sounds like your going to do your own work, what i would do is remove fork and seperate the leg, take the leg to a machinest and have him shave down the leg(ck with your local h.d.dealer or shop for a good machinest)then have booth legs chrome plated(good winter project, and you'll be able to say" i did it all by myself"
Old Jan 6, 2009 | 02:10 PM
cfoster80's Avatar
cfoster80
My uncle just put a set of Road King lowers (wanted dual discs) on Wide Glide tubes and used Duece tripple trees on his custom he is building. Dont see why you cant do it the opposite way. Try a Heritage too just make sure the tube size matches with lower leg size.
Good Luck.
Old Jan 6, 2009 | 02:59 PM
Gutman's Avatar
Gutman
Fat Boy and Heritage slider will work if using a Fat Boy or Heritage fender. The mounting tabs are in different location. Use Fat Boy legs and fender looks nice.
Old Jan 6, 2009 | 06:14 PM
shvlrydr's Avatar
shvlrydr
thanks gutman...i'm using a custom fender thats not drilled yet so mount tabs are not an issue.
Jaystn62
Oct 5, 2018 10:21 PM
Tx_Outlaw
Feb 23, 2011 06:47 PM
Tx_Outlaw
Feb 21, 2011 10:12 PM
fatheadonsoftail
May 9, 2009 03:14 PM
FUZZY
Apr 23, 2006 09:00 PM
