Detachable passenger backrest install
dapster it says 45-47 ft.lbs..
Might it be 45-47 in. lbs?
Thought it would take maybe an hour, but...
Relocated the air line, turned out to be a PITA.
After sliding that little red plastic locking thingy out, the airline still put up quite a fight.
Finally just ripped it out. Took me an hour to realign the little metal clippy thingy inside the air valve to reinstall.
Start drinking.
Mounted the air valve per directions, could not get pump to engage.
Removed air valve, inflated to 20 lbs, reinstalled. I'll deal with this later.
Continued installation...where are those flat metal bars that connect the two mounting points.
Oh, they're in with the sissy bar. Real cute MOCO. What sadistic packaging joker pulled this one.
Thought I was done, mounted the bags, OMG they look like crap.
Removed large spacers, then the fun begins.
Bolt for saddle bag bracket connects to a little square nut that is held in place by a metal clip.
DON'T let this pop out.
Nut in clip slides down the tube and out on the ground.
There must be a trick to replacing it, but none obvious to me.
After many trials and even more errors, I'm able to fish the nut into place with a piece of wire, but can't get the clip to hold.
Had to unbolt bracket and pivot it out of my way. Needle nose pliers too fat to hold nut in place and the clip is unwilling to help out, but I am able to get a bolt into it which frees up a hand to allow me to rehydrate myself.
Cold beverage must have woke up a brain cell I tried to kill in college...HEMOSTATS.
Grasp clippy thing from bottom with hemostats, pivot the bracket back in place, install bag mount, and just cranked the biotch tight.
Reinstall other two bolts for bracket, bags on, and looks good.
With sissy bar on, bag lids (when open) are a little tight against the quick detach cam lock. I can live with this.
Walk in the house, wifey sez "Gee honey, I'm sooo sorry you wasted a good riding day putting that backrest on for me." I smile weakly, crack open another, walk out back, cuss the MOCO, then kick her cat. Should have bought a solo seat instead.
