S/E Adjustable PushRods
Old Jan 13, 2009 | 11:40 AM
CndUltra95's Avatar
CndUltra95
Default S/E Adjustable PushRods
I'm looking at a set of used p/rods for a few dollars and appear to be in good shape.
Only thing is the guy doesnt have the tubes that came with the kit ( why I dont know ) , question being will they fit inside the stock p/rod tube? Do I need the SE Push rod tubes or..... does that help?
Then again, for a few dollars more I can buy new...
Thanks All,
Rob
Last edited by CndUltra95; Jan 13, 2009 at 12:59 PM. Reason: typo and clarafication
Old Jan 13, 2009 | 11:55 AM
skydoc's Avatar
skydoc
Screamin' EagleŽ Premium Tapered Quick-Install Adjustable Pushrods
These premium pushrods are tapered for enhanced clearance at the cylinder head, allowing the use of higher lift cams. The one-piece chrome moly tube adds rigidity and durability, and the threaded adjustment feature provides easy cam installation without removing the cylinder heads or rocker boxes. To simplify adjustment, the tube features six flats, with one flat marked with a large dot for tracking the adjustment. The threaded rod features 4 flats to reduce wrench swing. Each pushrod features the Screamin' EagleŽ logo and is marked for "Intake" or "Exhaust". Kit includes 4 pushrods and required pushrod tubes.
Old Jan 13, 2009 | 12:38 PM
HDRider2002's Avatar
HDRider2002
So what are you trying to say SkyDoc?
Old Jan 14, 2009 | 08:59 AM
Heathen's Avatar
Heathen
That the stock tubes wont work.
Old Jan 14, 2009 | 09:17 AM
Harleypingman's Avatar
Harleypingman
The older version of the SE adjustable push rods were known to rub inside the tubes. IIRC, the tapered SE adjustables replaced the older version and presumably won't rub the inside of the tubes.
Old Jan 14, 2009 | 09:22 AM
HDRider2002
Thanks Heathen for the clarification...i think they need a "sarcasm" smiley on this thing too!
xtratoy
Engine Mechanical Topics
11
Jun 15, 2014 04:33 PM
davlyo
Jan 22, 2012 06:43 PM
Glyder
Jun 29, 2011 12:37 PM
zoood
EVO
11
Jan 1, 2011 06:31 AM
atrain68
Dec 22, 2009 04:48 PM
