Unless I park on an incline I put mine in (N) before I shut it off. When the side stand is down it ain't going to go anywhere on its own.
Ditto, but I have a buddy who is the opposite...he will not park it in N ever....I guess this one ranks up there with the "Mobil1 vs. Amsoil" debates. there's going to be opinions on both sides that will never be swayed
To the OP, it was always my understanding you could shift with the bike off as long as you rocked it to keep the gears from mashing (as it looks like many have heard that)
As a part of my winterizing, I pull the plugs to spray in some fogging oil. Then I shift up through the gears to sixth and then push the bike around a little to get the pistons moving and distribute the fogging oil. After shifting up to the next gear I have to very slightly rock the bike back or forward. I hear a click in the trans and then can very easily shift to the next highest gear. Shift back down to neutral with the same procedure. Probably ruined my bike, right?
Probably not because it seems like you did it once. I don't think you do that every time you park the bike. When you get a bunch of parts in a basket and assemble them you have to shift things around to get it into neutral but you do not do that time after time every time you park or you do not understand much about machinery. Rocking the bike is correct but it is not the same as leaving the freekin thing in neutral like it is designed to be.
I leave it in gear if theres a chance of rolling (slight incline). But I made the Mistake "ONCE" of not looking at the neutral indicater on the dash and started it while standing along side the bike. IT ALMOST LEFT WITHOUT ME. Scared me to death, now I always look to be sure. That may be a reason why they don't want you leaving it in gear, cause she'll start in gear.
Was wondering if I could get some insight on why the owners manual recommends not shifting the gears when then engine is turned off? "Shift to neutral before stopping engine. Shifting mechanism can be damaged by shifting gears while engine is stopped." I know some like to leave bike in gear (self included,) when shutting down to prevent rolling etc when parked. Is there really any harm rocking the bike back in forth w/ clutch pulled in when shut off to find neutral before hitting the starter??
Road King seems to be prone to surging forward if started in gear w/ clutch pulled in, so unless you are going to always leave in neutral, there may be issues over time.
Let me know your thoughts...
Hey Jeff. I knew you would get varied opinions on this.
Always leave it in gear when sutting engine off. Usually put it in neutral prior to starting, never saw that statement in the manual. I don't see that being a problem as long as you use some common sense and don't force it into neutral.
After riding Harleys for several decades I decided to join a good internet forum and learn about all the things that I should have learned years ago. I never realized just how fragile a Harley is. They always seemed so solid and damn near indestructible to me.
To make a long story short, I confess that I have been doing things wrong sometimes and right sometimes but I have never damaged an HD engine or tranny, or clutch for that matter. In my earlier days I would park and start the scoot in neutral (always with the kickstart gal). Occasionally, I would forget and leave it in gear and have it scare the hell out of me when it jumped forward under the power of the starter. Now I leave it in gear, usually start it in gear with the clutch pulled in and many times shift gears with the engine not running. I may go to hell for mistreating my Harley but, dang, it sure seems tough and trouble free.
I have always parked mine in neutral. I prefer not to load the starter anymore than I have to when I start the bike. I even shut it off a lot of times before I shift to neutral and I have been riding for 38 years without any tranny troubles. Common sense should tell you not to force the shift. Unloading the tranny is just too easy before you put the side stand down.
Now I have jinxed myself and it will brake the next time I do it.....LOL.
I feel so much better now thank you Boy for a min there this thread scared me........LMAO
