Ultra CB mike?
Old Feb 1, 2009 | 08:42 AM
cdestuck's Avatar
cdestuck
Default Ultra CB mike?
Was messing around with the Ultra since it is not quite nice enough for riding. Thought I'd check out the CB (09 Ultra). For the first time, opened up the box with the passenger headset in thinking there would be a CB mike there. No mike. Was a mike to be included with the bike or not? And, is it possible to listen to CB without using a mike? Thanks
Old Feb 1, 2009 | 08:44 AM
canuck pride's Avatar
canuck pride
Yes just switch the switch on the dash and it will play over your speakers.
Old Feb 1, 2009 | 09:00 AM
rfultra's Avatar
rfultra
You can use, (listen and talk) your CB without a mike. Listen through the speakers, or headsets, and talk through the mike on your headset. Great setup, i use mine a lot. Good luck.
Old Feb 1, 2009 | 09:20 AM
Chicago Spike's Avatar
Chicago Spike
Do you really WANT the passenger to be able to talk to you while riding???
Old Feb 1, 2009 | 09:51 AM
peddler's Avatar
peddler
Easy answer...NO! That's why the Ultra's come with only one head set.
Old Feb 1, 2009 | 12:19 PM
cdestuck's Avatar
cdestuck
Flipping through the modes on the radio, I can't seem to see mode for the CB, and to change between cb channels.
Old Feb 1, 2009 | 01:52 PM
Chasenfish's Avatar
Chasenfish
On my '08, it's the COM button that gets you into the CB setup, then use the MODE SEL switch up or down to select channel. Not sure if your "09 is the same or if it's changed.
Mine did not come with a CB mic, just the headset, and that's all I use. If you want to use it without the headset, get a mic to plug in. Harley has one for about $100, part number 76312-98. A buddy of mine has an aftermarket one he got on E-bay for about half of that.
I use my CB a lot on longer trips, especially when riding with a group.
Old Feb 1, 2009 | 01:56 PM
dawg's Avatar
dawg
Originally Posted by cdestuck
...... the Ultra since it is not quite nice enough for riding.
Old Feb 1, 2009 | 02:03 PM
Chasenfish's Avatar
Chasenfish
Originally Posted by dawg
I think he means the weather isn't nice enough for riding, not that the Ultra isn't.
Old Feb 1, 2009 | 02:18 PM
dawg's Avatar
dawg
Ahhh, I get it now
