Arlen ness big sucker II
Old Apr 18, 2006 | 06:29 PM
cleetusdfw's Avatar
cleetusdfw
6th Gear
Default Arlen ness big sucker II
Will a big sucker filter assembley fit on my 06 SG? All the adds say it fits up to 2005 flt, and wont fit 2006 inj models. Did'nt the 2005 use the same delphi inj? some help before I purchase would be greatly appreciated.
Old Apr 18, 2006 | 06:35 PM
Inforit's Avatar
Inforit
Default RE: Arlen ness big sucker II
I have heard a couple of months ago that the big sucker will not fit on the 06 models and that the 06 version should be out around this time.
Old Apr 18, 2006 | 07:35 PM
PhilM's Avatar
PhilM
Not sure about the air cleaner assemblies, but the throttle body is slightly different on the 06's...
Old Apr 18, 2006 | 08:57 PM
blowe's Avatar
blowe
I bought a "Big Sucker" two weeks after I purchased my bike.
I don't get the "it won't fit" but I have heard the same thing.
It mounted up with no problems.I have 10k trouble free miles with it installed.
Signed into my Dennis Kirk account and this is what I purchased.
1-Part# H30647
Stage I Big Sucker Performance Air Filter
Units: each 4.81 Lbs. $104.99
1- Part# H49761
8 in. Smooth Air Cleaner Cover
Units: each 5.68 Lbs. $56.99
Old Apr 18, 2006 | 09:21 PM
Big Dog's Avatar
Big Dog
I worked at a local bike shop during the winter months. I put a Big Sucka on my 04 Ultra, buddy of mine bought an 06 Street glide and we tried to put a Big Sucka on his bike, The shop went thru Drag Speciality to buy these items. Drag stated that the Big Sucka will be available for the 06 models by Jume 2006.
Keep the Chrome side up and ride safe.......
Old Apr 18, 2006 | 10:03 PM
jfanton's Avatar
jfanton
ORIGINAL: Oliver Clozoff
1-Part# H30647
1- Part# H49761
Is your bike an '06? As has been said, there is a change to the throttle body, I believe (another) sensor was added. I have been told that you can grind off the obstruction and the backing plate will then fit.
Of course if there is a warranty issue with the throttle body...
Old Apr 18, 2006 | 10:07 PM
jdag's Avatar
jdag
Not sure of the Ness model I originally purchased. But back in Aug I tried the Big Sucker on my 2006 Street Glide. It did not even come close to fitting. It was off by close to an inch. I ended up using the SE stage 1 kit.
I did hear that Ness was going to come out with a 2006 compatible model, but not sure if that it out yet.
Old Apr 18, 2006 | 11:10 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
I saw the HD Indy shop that worked on my bike installing a Ness on an 06, but he had his die grinder out doing some massaging to make it fit
Old Apr 19, 2006 | 01:17 AM
Rodman813's Avatar
Rodman813
I talk with the guys from Arlen Ness every other week. They will not be availble until the end of April. I've had one on order since Feb. So hopefully soon.
(AN says harley changed the throttle on the 06s therefore the older ones will not fit/work properly
Old Apr 19, 2006 | 02:15 AM
Rhinohd's Avatar
Rhinohd
Yep I thought it would fit on my brother inlaws 06 but I was wrong
I hate it when that guy is right LOL
