Changed fork oil AGAIN tonight + stupid mistake
Old Feb 4, 2009 | 07:00 AM
kjmorgan's Avatar
kjmorgan
Do the same thing to the other fork and at least they'll be equal, right?
Old Feb 4, 2009 | 07:06 AM
captjon37's Avatar
captjon37
Wow, nothing better to do eh?
Old Feb 4, 2009 | 07:53 AM
chasswartz's Avatar
chasswartz
That little bit of oil is not going to make a difference, and yes you can mix oils.
Old Feb 4, 2009 | 08:19 AM
sniper77's Avatar
sniper77
Ah what the heck?
You're supposed to be a biker and they like "living on the edge".
That said, I'd probably recommend using BelRay fork oil simply because you know it's the best there is and it's available in every weight you could possibly want to try.
Old Feb 4, 2009 | 08:30 AM
bagman1's Avatar
bagman1
?????????????????? OK!
I went from stock fluid to SE oil and what a difference it made, that with Metzlers it rides so smooth now.
Old Feb 4, 2009 | 08:38 AM
ken thompson's Avatar
ken thompson
The Schlong Man
Originally Posted by BigG2009FLHRC
They all nose dive when you slam on the front skid.
+1 Slow down and quit driving like a maniac.
Old Feb 4, 2009 | 08:48 AM
EasternSP's Avatar
EasternSP
Unless you completely rinse out the old oil residue from inside the front forks you are going to get a mix of some degree.
Unless every oz of oil is going to be utilized in the functioning of the fork, I wouldn't think a 1/2 oz would be that important. There is always a reserve amount factored in to allow for leakage until a repair can be performed, otherwise, you're in trouble and have to trailer the bike at the first sign of a leak. Sorta like your tranny or engine. You have a oil level range to stay within.
Old Feb 4, 2009 | 08:56 AM
gunner11's Avatar
gunner11
I can't understand why you're screwing with it? It's an 09 dude make the dealership fix it.
Old Feb 4, 2009 | 08:58 AM
gunner11's Avatar
gunner11
+1 on romping on it so hard it nose dives, get some good riding habits!
Old Feb 4, 2009 | 11:55 AM
bnelele's Avatar
bnelele
Deep down inside you know you want it to be done right. Give yourself a day or so to get over the mistake and then tackel it again when your not upset.
