Help needed!
Old Apr 19, 2006 | 03:30 AM
KenFichtner's Avatar
KenFichtner
Default Help needed!
I have a new Ultra Classic on order (06).
I am desirous of changing the air intake to a Harley Screamin Eagle and changing the exhaust.
My dealer told me that Harley has discontinued offering the tuner and the off road pipes.
Which pipes and tuner do you recommend. I want performance and I want to hear the pipes!
Old Apr 19, 2006 | 03:51 AM
Matt8643's Avatar
Matt8643
Default RE: Help needed!
For tuner I would recommend PCIII. Other than the SERT it is the most advanced of the tried and true tuners. I have a PCIII myself and am happy. I say the tried and true because I read that a few new EFI tuners have been released, but I haven't read any first hand reports about then yet.
As for pipes I couldn't tell you, I have S&S SPO's specifically because they add performance but are quiet.
Old Apr 19, 2006 | 09:18 AM
zubaugh's Avatar
zubaugh
I run with a SERT and T-Rex 3" True Duals from Hard Krome on my 05 Ultra. They are sweet and bring back the old harley sound. I believe the SERT is still available. But finding a dealer capable of tuning with one may be a bigger issue. The Power Commander PCIII is a good alternative albeit another device subject to failure. It you can't get the SERT and flash the ECM directly, then the PCIII add on is what I'd go with.
Old Apr 19, 2006 | 10:00 AM
PhilM's Avatar
PhilM
I agree the above posts regarding the PCIII. I have had them on several bikes, including my current RG.
The S/E high-flow air filter setup is good one. "If" you can, request one that has the "K&N" filter in it. Recently, they started using a different one that has a blue molded seal around both ends.
Given your stated selection criteria regarding pipes (Performance & Sound), you shold consider either a D&D FatCat or a ThunderHeader. Both are 2 into one pipes, but they definitely offer better performance. I have used 2 into 1's on an ElectraGlide and two RoadGlides. For me, they look great and the performance make them a no-brainier. Again, that's just one opinion. I'm sure we'll see some more.
Old Apr 19, 2006 | 10:31 AM
bountyhunter's Avatar
bountyhunter
Help indeed......here is what you need! The SWEETEST set of FAT true duals, guaranteed to ROCK.
Old Apr 19, 2006 | 10:47 AM
CHEYENNE's Avatar
CHEYENNE
SERT or PCIII
Exhaust is a matter of opinion. Try and hit some local spots or dealerships to listen to the exhaust to see which you favor.
FILA
Aug 24, 2008 12:45 AM
LNEMUP1
Jan 24, 2007 03:08 PM
harleybiker
Oct 16, 2006 12:36 PM
GliderXXX
Aug 10, 2006 08:55 PM
MikeP
Jan 31, 2006 05:37 PM
