Starting to have issues
Old Feb 6, 2009 | 08:42 PM
MJR's Avatar
MJR
Default Starting to have issues
Kind of slow when I first hit the starter, then it cranks up and starts fine. What do you think causes the hesitation?
What should I be looking for?
Old Feb 6, 2009 | 08:46 PM
rbabos's Avatar
rbabos
Sounds like a weak battery or poor connections with the main starter cable or grounding. Compression could be higher than normal from carbon build up.
Ron
Old Feb 6, 2009 | 08:50 PM
CndUltra95's Avatar
CndUltra95
check the battery connections.
ground connections ,
thats about all I can think of right now.
Might wanna throw a volt meter on it when it does flash up and see what it is charging at.
Rob
Old Feb 6, 2009 | 09:30 PM
MJR's Avatar
MJR
Thanks, I'll check the connections tomorrow. Probably is the battery, I picked the bike up a year and a half ago so I don't know how old the battery is.
Thanks,
Mike
Old Feb 6, 2009 | 09:44 PM
Trock's Avatar
Trock
If it's the original battery then it's probably due [03] But like they said the cables may need cleaned. My friends was doing the same thing a few days ago and that fixed it.
Old Feb 6, 2009 | 09:54 PM
SoCal_Pappy's Avatar
SoCal_Pappy
BATTERY would be the first place to start... Get a load test done.. Some auto parts stores will check it for free...
Hx3's Avatar
Hx3
I would recommend saving yourself some problems and changing your battery. Had the same symptoms on my 99 and it turned out to be the seven year old battery.
Old Feb 6, 2009 | 10:07 PM
FLoTR's Avatar
FLoTR
Hey MJR, dats one niiiiiice scooter u got there
Old Feb 6, 2009 | 10:20 PM
MJR's Avatar
MJR
thanks FLoTER,
It runs good for a stock motor. I really like the color, and the RG handles great.
Mike
Old Feb 7, 2009 | 02:07 AM
leon anthony's Avatar
leon anthony
Mine was doing the same thing as you say my battery was 3 years old everything
was real clean so I thought it was the battery so I bought a new one from H-D
$160. While removing old battery I discoverd that the ground cable was not thight
My old battery was still good. Oh well now I have a new one
