Pull Back for 08 Ultra
Old Feb 7, 2009 | 01:20 AM
Born2cure's Avatar
Born2cure
Default Pull Back for 08 Ultra
I would like to put the pull back bars on my 08 ultra classic. I have ABS which I think is workable, but I also have the harley heated grips is there a way to to keep the grips.
any help would be great
Thanks
Old Feb 7, 2009 | 06:46 AM
Odd Job's Avatar
Odd Job
Check out the ..
Wild 1
WO575
10" RISE, 13" PULLBACK
34.5" WIDE, 14" CENTER WIDTH
have them on my 09 Ultra Classic...love em!!
Old Feb 8, 2009 | 07:14 PM
hamnhog's Avatar
hamnhog
From what I've learned recently, H-D is not yet making replacement brakelines for 08 ABS. If somebody tells you that you can do this mod without changing brake lines, make sure you know what they intend to do before they start. Protect yourself and your ride. The WO575's on my 09 required longer clutch cable and longer than expected brake line. Good luck. And it is worth the trouble.
Old Feb 8, 2009 | 07:24 PM
JohnB445's Avatar
JohnB445
Check the HD web site under accessories. The bars that will not work with ABS
have a notation. Then check handlebar spec page, to see if what you want, will work.
I was looking at mine today. It looks like the front brake line could be rerouted, and
pick up a lot of slack. But HD won't do that, you have to do it yourself.
Old Feb 8, 2009 | 08:28 PM
baggerman's Avatar
baggerman
Default Pull backs
B2C
I put on Khromewerks Sweepers on my 08 SG. Very nice. I've got ABS. Paid $70.00 for them. Needed +4 clutch cable, the rest factory. You might also check Flanders for their narrow pull backs.
Good luck
Old Feb 9, 2009 | 06:33 AM
Peppa1's Avatar
Peppa1
I have 08 Ultra and went with the Khrome Werks +2 Sweeper bars and all you need is a +3 or +4 clutch cable (depends on where you buy cable). Everything else works fine. This is with OR without ABS.
VB2KDH
Mar 31, 2013 08:48 PM
Born2cure
Oct 21, 2008 07:34 AM
Born2cure
Aug 29, 2008 10:44 AM
Ranger1
Mar 12, 2008 11:05 AM
Ranger1
Mar 11, 2008 03:55 PM
