Batwing question
Old Feb 8, 2009 | 08:10 PM
mrmike38z's Avatar
mrmike38z
Question Batwing question
I have had mine apart several times for various reasons but when I go to put it back together it does not completely seal. Some sections have 1/16 or so gap and some do seal. Is this thing supposed to be water tight or not?
Old Feb 8, 2009 | 08:21 PM
stro1965's Avatar
stro1965
I don't think they were meant to be watertight but the halves should seal against one another. If they don't, something is holding them apart. I went through this a couple weeks ago on my own bike. The left side wouldn't close up near the grip. I had rerouted some wires (GPS power and audio cables) and they were pushing the outer fairing out. Once I figured it out the halves closed up again.
Old Feb 8, 2009 | 08:24 PM
CndUltra95's Avatar
CndUltra95
I dont think it was water tight from the factory, resistant yes, but water tight....
I would go back and see where it might be binding.
As for the 1/16'' gap, maybe a picture or a better description where the gap is.
On my 02 Ultra, near where the wind screen meets at the edges there is and always has been a lil gap that water has and does run down....45,000 miles and still no electrical troubles...Dam now I just jinxed myself.
Rob
Old Feb 8, 2009 | 08:30 PM
hollywoodultra's Avatar
hollywoodultra
I just put mine back on today and dont have the gaps that you are speaking of, I would assume like the others stated...something is holding it out. Mine is not waterproof, I have moisture in mine after a hard rain.
Old Feb 9, 2009 | 02:45 AM
hogbag07's Avatar
hogbag07
The brass nuts in the fairing can back out from over tightening they should be glued back in or replaced with the better units from Harley
Old Feb 9, 2009 | 05:36 AM
Frankie-FLHXI's Avatar
Frankie-FLHXI
great thread
Old Feb 9, 2009 | 06:00 AM
Jrsess's Avatar
Jrsess
If you over tighten the screws you can pull the inserts out of the plastic. When you close it up it won't close all the way.
Old Feb 9, 2009 | 06:01 AM
Jrsess's Avatar
Jrsess
Almost forgot, HD makes a repair kit for that!!
Old Feb 9, 2009 | 06:09 AM
bdp's Avatar
bdp
+ 1 on this, the better inserts are about a $1 and will not back out once installed.
Old Feb 9, 2009 | 06:19 AM
rjmac53's Avatar
rjmac53
Thanks for the repair kit tip...
