Road Glide Headlite Cover
Old Apr 7, 2005 | 11:14 AM
Old Blue's Avatar
Old Blue
Default Road Glide Headlite Cover
How do you remove the headlite cover to clean the inside? Is there a way to do it without taking off the fairing?
Thanks Everyone
Old Apr 7, 2005 | 12:30 PM
LAF's Avatar
LAF
Default RE: Road Glide Headlite Cover
Yes use a nylon stick and Gently pry each top corner down until you get it to pop off. Go easy there are tabs that can break if you are rough on it. Make sure it is a little warm as in the sun on it for a bit. I don't do mine in the winter because of the cold and I only have a carport. Use gentle pressure and go slow and no issues.
Old Apr 7, 2005 | 01:22 PM
Old Blue's Avatar
Old Blue
What is a nylon stick?
Old Apr 8, 2005 | 01:41 AM
mikeisglidn's Avatar
mikeisglidn
a stick covered in your wifes new nylons
well, maybe not......
Old Apr 10, 2005 | 11:28 AM
JSY's Avatar
JSY
I use a small head screwdriver that I covered with duct tape. I covered only the head, works all the time no problems.
Make sure the cover is replaced the correctly and check that it is snapped in and secure before you take it for a ride or it will fall out.
Jeff
agapsdiver
Nov 18, 2010 08:31 PM
CLASSICRYDER
Touring Parts
Jan 22, 2010 05:12 PM
NoCoLoco
Jan 11, 2010 08:02 PM
semiret
Sep 4, 2009 10:07 PM
snoopy
Feb 13, 2007 08:31 PM
