Fog light question
Old Feb 13, 2009 | 08:26 AM
harley-jones's Avatar
harley-jones
Default Fog light question
Are all the connections for the fog lights (that mount on the crash bars) made inside the fairing on a SG?
Or would I need to pull the fuel tank for any reason.
If someone that has done this could give me an install step by step if would be appreciated.
Also, do the fog lights have a switch of their own or are they wired to the low or high beam headlight circuit? Do they use a relay?
Dealer wants 1.5 hours labor plus the cost of the lights! I might tackle it myself if not too involved.
Thanks in advance!
Old Feb 13, 2009 | 08:32 AM
dawg's Avatar
dawg
What's your email addy and I'll email the instruction sheet to you so you can see what's involved
Old Feb 13, 2009 | 08:41 AM
harley-jones
Thanks Dawg!
Old Feb 13, 2009 | 08:47 AM
dawg's Avatar
dawg
comin' at ya
Old Feb 13, 2009 | 09:00 AM
harley-jones
Thank you sir!
Old Feb 13, 2009 | 09:05 AM
georgemcghee's Avatar
georgemcghee
could i also get that sheet
crappiepro@mchsi.com
Old Feb 13, 2009 | 09:07 AM
bluelab's Avatar
bluelab
6th Gear
Default fog lights
Wiring runs under the fuel tank as the power connector is located by the battery. But removing the tank is easy on the 08. I recently installed the HD fogs on my 08 SG and was not looking forward to removing the tank, but it was a piece of cake.
I decided to wire the lights into the SG's accessory switch instead of using the handlebar switch that comes with the kit. This is an easy mod that requires purchase of an Y connector for the accessory plug that is also by the battery. once this is wired up you activate the fogs by the accessory switch on the fairing cap.
I'd be happy to provide details of the accessory switch wiring if you are interested.
-bluelab
Old Feb 13, 2009 | 09:11 AM
dawg's Avatar
dawg
Thumbs up
On the way
Old Feb 13, 2009 | 10:50 AM
oinker02's Avatar
oinker02
I suggest you forego the supplied push button switch .
The supplied push button mounts to clutch clamp screw and looks kindy hokey. It also adds another exterior wire run to your bars.
I've got mine wired to trigger off passing lights, plus I swapped my passing light switch with the acessory switch so it's on the left vs right.
Old Feb 13, 2009 | 06:26 PM
sat4314's Avatar
sat4314
Default Instructions
Pass the instructions to me as well please
urtalkin@yahoo.com
Thanks
