shifter linkage
Old Feb 19, 2009 | 08:11 PM
cirhere2's Avatar
cirhere2
Default shifter linkage
someone posted a web site were you could get stainless steel or chrome linkage
I need the ends with the hyman joint any help guys
Thanks
Russ
Old Feb 19, 2009 | 08:13 PM
tima's Avatar
tima
PM stro1965, he had the link, just bought the heim joints.
Old Feb 19, 2009 | 08:15 PM
stro1965's Avatar
stro1965
If you want the full linkage they are everywhere, HD, Kuryaken, etc...
If you're looking for the heim joints, this is where I bought mine but I'm sure you could find 'em on eBay too:
http://www.mcmaster.com/#
Old Feb 19, 2009 | 08:29 PM
stro1965's Avatar
stro1965
Part Number: 59915K483 $11.34 Each
Rod End Type
Ball Joint Rod Ends
$11.34 each
Attached Thumbnails shifter linkage-itemdetailscreenballjointhighstrengthptfelinerfemale.gif
Old Feb 19, 2009 | 08:41 PM
SDO6's Avatar
SDO6
I am not catching the reason this should to be changed out...someone explain.
thanks
Old Feb 19, 2009 | 08:49 PM
EasternSP's Avatar
EasternSP
Thanks Stro. I just ordered a set.
SD06, the part on your shift linkage that you have now will fail and your linkage will fall apart. It happened to mine last summer and my scooter was only two years old.
Old Feb 19, 2009 | 09:14 PM
SDO6's Avatar
SDO6
Thanks, Got more research to do.
Old Feb 19, 2009 | 09:19 PM
skratch's Avatar
skratch
i know that you've already ordered yours, but if someone else is interested, racebasics on ebay. 5/16 - 24 rh female heim joint. 2 plus shipping comes out to 8 bucks and some change. great if you don't have to have the chrome ones.
Old Feb 19, 2009 | 09:39 PM
oldmanwayne's Avatar
oldmanwayne
thanks
The stock shift linkages' ball joint ends are somewhat prone to failure- one way to fix it is with the above mentioned heim joints
Old Feb 19, 2009 | 10:49 PM
05 HD Deluxe's Avatar
05 HD Deluxe
This is where I bought mine. Polished Stainless rod and heim joints
Around 50 bucks delivered They sell just the heim joints also.
http://stores.ebay.com/HARLEY-PARTS-...QQftidZ1QQtZkm
