bead expander
Old Feb 20, 2009 | 10:33 PM
shorty07ultra's Avatar
shorty07ultra
Default bead expander
I am thinking of changing my own back tire on my Ultra with Cast wheels. I was looking through the service manual and it stated something about a bead expander. Wanted to know if anyone uses one that does their own tire changes at home. Also do you need to put some type of lubicant on the tire when setting the bead. I have done engine work before but never a tire change and decided I needed to learn something new.
Old Feb 20, 2009 | 11:15 PM
FLTR2008TRIKE's Avatar
FLTR2008TRIKE
if you dont have a high volume compressor you can use a tie down strap around the tire to help air it up
Old Feb 20, 2009 | 11:51 PM
stu07hd's Avatar
stu07hd
I have changed several MC tires and havn't heard of a bead expander, or needed one. Like the post above says, If you cant get the bead to set put a racheting tie down strap around the tire and ratchet it tight. It will make the tire want to flatten out and help the bead set.
Old Feb 21, 2009 | 03:02 AM
AtkRWC's Avatar
AtkRWC
Leave the needle valve out of the valve stem when setting the bead. Use either the airhose end without a chuck or use an air gun and you will get the volume you need with most garage compressors. Soapy water works fine as lube.
Old Feb 21, 2009 | 04:28 AM
shorty07ultra
Thanks, I think I will be making a run to Harbor Freight for some new toys now.
Old Feb 21, 2009 | 07:41 AM
leon anthony's Avatar
leon anthony
you can get a air tank. that way you can air up the tank with a low folume compresser
then have full volume out of the tank for setting the bead. You can get them at any auto parts store.
Old Feb 21, 2009 | 08:00 AM
blueflht's Avatar
blueflht
use dish soap and lube the snot out of it!. the more lube the easier it is. when working with low pro tires be careful not to tear the sidewall bead
Stamant59
Aug 3, 2017 11:12 AM
Griff012FLHX
Sep 19, 2014 09:43 PM
a10182
Nov 20, 2011 08:45 PM
maryland blackout
Aug 2, 2010 10:07 AM
gipsl67
Wheels/Tires
Jul 28, 2009 01:07 PM
