battery charger and driver adj backrest
Old Feb 24, 2009 | 08:08 PM
Raventhik's Avatar
Raventhik
Originally Posted by bnelele
I have the adj backrest on my 08 ultra and to remove it I stick my fingers down thru the seat and where the backrest slides down into the bracket you have to pull the bracket apart with the tips of your fingers and then pull the backrest up and out of the seat. Then to put it back in reach down into the seat and slide the backrest inbetween the two piceses of metal and pull it apart then the backrest will slide in and lock. Kinda like making a v with two fingers on your right hand and then taking a finger on your left and sliding it down into the v. Hope that makes sense....The v is springey and can be pulled apart with your finger tips
This is the same as my 06 ultra.
Old Feb 24, 2009 | 09:32 PM
alto's Avatar
alto
I'd guess it's the small ( 7.5 amp I think) mini fuse in line. My buddy and I just tracked down the very same problem with his 08 ultra..The mini fuse, in line, was shot.
Krazy8s
Dec 2, 2016 08:48 PM
turkeybird42
Jan 11, 2015 04:49 PM
BlueOcean
"The Florida Crew"
23
Nov 20, 2013 06:34 PM
bama6977
Jan 4, 2012 10:29 PM
Jul 3, 2009 08:23 AM
