Signal Lite fuse location
Old Mar 6, 2009 | 04:56 PM
grizz07's Avatar
grizz07
Stage II
Default Signal Lite fuse location
Can anyone help me with this? 2004 Ultra, chaffed wire blew a fuse and now signal lites, speedo, tach, brake lites and cruise control no longer work. All fuses under left cover are good. Is there a hidded location for this fuse? I'm stuck on the road in San Angelo, Texas and my manual is 3000 miles away. Any help would be appreciated.
Thanks
Grizz07
Old Mar 6, 2009 | 05:08 PM
tombeving's Avatar
tombeving
I checked my service manual and the signal lights are #3 in the fuse block, instruments are #4, and brakes and cruise control are #5. Since your problem is three different fuses, you may have blown the maxi-fuse. You can find it behind the left-side side cover. Hope this helps.
Old Mar 6, 2009 | 06:55 PM
grizz07's Avatar
grizz07
Stage II
Thanks for the quick reply. All the fuses in the left side fuse block are good. I switched them around the make sure. I swapped relays. The main fuse is good. The bike runs. The cruise control doesn't work because the speedo doesn't work. I ran a wire direct from the battery to the signal lite lead and everything works as it should. I can make a semi permanent fix with a piece of wire twisted together and untwist when I shut the bike off. I can't figure out what provides power for this circuit.
Brettfullthrottle
EVO
Mar 31, 2015 08:05 AM
HaDa_Dude
Sep 10, 2013 07:38 PM
EVOrider
EVO
May 27, 2010 12:18 PM
tbonetcs
Apr 1, 2010 01:46 PM
bigdonhd
Nov 25, 2004 06:33 PM
