I wonder how I have managed to tank 19,7 Litres at the gasoline station into my SG tank?
19,7 litre = 5,20418941 US gallons
And another thing is that the back end of the tank is very unsymetric, when I remove the seat and look at the en fo the tank, the left side goes as a straight line like cutted straight and the right side does a curve.
Normal?
-Mikael
It might be that the gasoline stations pump need to be reclibrated also but I don“t think so
it is because the pumps are not calibrated...................tank holds 5 and if it is on the side stand it will flow out!!!!!!!!! call the county because the a$$hole at the gas station is $crewing people over
May be the case but also realize that the manufacturer has to state the minimum capacity only and maybe due to variances in the manufacturing process some tanks may very well indeed exceed the stated capacity.
