I've decided to do my own 1000 mile maintenance on my 09 streetglide. I need to buy a manual. Does anyone know the part number for one of these and where I can get the best deal on it? Thanks in advance.
Thanks Kowalski. I'll give them a try. 2 weeks isn't a problem.....it's 12 degrees outside and there's snow everywhere. I got some time (unfortunately).
I'm going to do this as well. When I looked at the list and compared it to the manual, only the clutch adjustment look hard. I will be asking for advice when that time comes.
All you really need is a good torque wrench...service manual steps are straight forward with this procedure.
Only tip I have is make sure you have the bike in gear, on a stand...but keep it so the rear wheel is touching the deck. If the bike is straight up then you'll lose no oil out of the primary. On the side stand you may lose a little. The rear wheel contacting the ground helps when turning the nut on the clutch basket.
