V&H Basic Slip-ons Install
Old Mar 13, 2009 | 06:21 AM
ElectraGlideSteve's Avatar
ElectraGlideSteve
I put on the V&H basic slip ons last year and used the original stock HD clamps that came on the bike (new bike, only had 200 miles on it when I swapped). Have had zero problems and no leaks. The V&H clamps are junk. If you can hold a wrench, the entire job should take less than 45 mins.
Old Mar 13, 2009 | 07:10 AM
fatboy4447's Avatar
fatboy4447
i'm mutli-talented I could probably hold two wrenches at once haha....thanks for the input....its a 09 with 560 miles on it so its brand spanking new.....how do you like the sound?
Old Mar 13, 2009 | 09:12 AM
ElectraGlideSteve
I think they look and sound great. Nice rumble at idle and they really wake up when on the throttle. Very happy with them.
Old Mar 13, 2009 | 11:55 AM
milleda31's Avatar
milleda31
I spent about two hours yesterday afternoon putting Vance and Hines slip-ons on my 08 SG. In addition to the slip-ons, I also installed a HD hi-flow AC and a Vance and Hines FuelPak.
The slip-ons took about thirty minutes. Squirt the stock mufflers with some WD40 prior to pulling them off. I used the stock clamps.
The FuelPak took about thirty minutes including entering all the codes.
The AC took about an hour because I really took my time removing the brace behind the backing plate. I didn't remove the gas tank. I used a long allen wrench and guided it in with my fingers. Took quite awhile to back the bolts out because I used extreme care not to scratch my tank.
The sound is great in my opinion. Not obnoxiously loud but certainly an improvement over stock. I had the same setup on my RK and when I traded the RK in on the SG the dealer let me take the slip-ons, FP, and AC off and replace them with the stock parts. I waited until I had 1k service done on the SG and then made the changes.
Very easy job. I am by no means a mechanic and I didn't have any trouble at all. Just take your time.
Old Mar 13, 2009 | 12:37 PM
sinjin's Avatar
sinjin
A little penetrating oil sprayed where the muffler join the head pipe might make removal easier.
Old Mar 13, 2009 | 04:04 PM
fatboy4447's Avatar
fatboy4447
thanks guys....now i just gotta wait for them
Old Mar 13, 2009 | 11:03 PM
Bamboo's Avatar
Bamboo
Just got the 09 Basics and they came with the good/torca clamps!
Old Mar 13, 2009 | 11:58 PM
webbhead's Avatar
webbhead
Good Tech info here! Thanks to all I am going to do the same thing!
Old Mar 14, 2009 | 01:34 AM
Silverstone's Avatar
Silverstone
Did mine in no time at all,fastened everything up good and tight,put the bags back on and then noticed I'd pushed the left one in 1/4 inch further than the right
Make sure everything lines up before you put the bags back on!
If you're doing the Air cleaner/V&H FuelPak too, e-mail V&H tech support for the settings,they were very helpful to me.
They sound great BTW.
Old Mar 14, 2009 | 06:17 AM
Jrsess's Avatar
Jrsess
30 minutes, 1-2 beers!
