Where did you install the temp sensor
Old Mar 14, 2009 | 09:08 PM
GT_RoadGlide's Avatar
GT_RoadGlide
Default Where did you install the temp sensor
Where did you install the temp sensor for the temp guage? On my 07 RG it installs in an adapter that fits between the engine and oil filter. Oil temperature is sensed after it goes through the oil filter. If the oil filter filters oil before it goes into the engine then this oil should be cooler than oil coming from the engine. Maybe it doesn't matter. Just thinking...
Old Mar 14, 2009 | 09:36 PM
BadPiggy's Avatar
BadPiggy
Mine is crammed in the oil pan, the plug next to the oil drain plug.
Old Mar 14, 2009 | 09:49 PM
iclick's Avatar
iclick
There are numerous threads on this topic here. Search on "oil cooler pan" (no quotes and you should find plenty of info and testimonials. Basically, the HD solution for sender location is inane, and you're much better off buying a $2 adapter from Napa #3220 x 6 x 2 (1/8"F-3/8"M) and install the sender in the oil pan (Allen plug to the right of the drain plug).
rhallman
Dec 29, 2020 12:21 AM
kurtv52
Nov 20, 2014 09:03 PM
hobbes2
Aug 23, 2014 09:11 AM
ajay450
Feb 24, 2011 06:11 PM
tarheelrdr
Jul 15, 2007 04:17 PM
