Plug at the front of the oil pan?
Old Nov 20, 2014 | 07:30 PM
kurtv52's Avatar
kurtv52
2nd Gear
Default Plug at the front of the oil pan?
What is this for? Could it potentially be used to install an oil temp sensor?
I have an fxrp fairing installed on my bike and an HD oil temp sensor installed in it...curious to see if this plug could be used to install the sensor or if it would be better off installing a T-fitting on the drain plug or oil return line.
Any ideas?
Old Nov 20, 2014 | 08:41 PM
jmn1960's Avatar
jmn1960
if it is the same as on a tc88 , that is where i put my oil temp sensor
Old Nov 20, 2014 | 08:48 PM
bdtaylor1979's Avatar
bdtaylor1979
I read on another thread that that is where you install the sensor for an oil temp gauge.
Old Nov 20, 2014 | 08:52 PM
Gliden's Avatar
Gliden
The one that the manual says " do not remove"...yea oil temp sensor goes there.
Also if your running an oil cooler you could by the adaptor that has an oil temp port on the oil offset adaptor and put the temp sensor in the adaptor.
Old Nov 20, 2014 | 09:03 PM
kurtv52's Avatar
kurtv52
2nd Gear
Yeah, TC88...forgot to mention the bike is an 02 FXDX
hobbes2
Aug 23, 2014 09:11 AM
BornTexan
Mar 2, 2014 07:13 PM
johnica
Aug 2, 2011 07:15 PM
GT_RoadGlide
Mar 14, 2009 09:49 PM
gsparesa
Dec 18, 2005 04:52 PM
