Mine's been leaking since day one (between top rocker-box and middle spacer). Apparently, the gasket keeps popping/sliding out of place... blowing oil everwhere! The dealership has tried to fix it twice and now they're going for a third.
I haven't even finished the 500 mile break-in, yet. Tech support at Harley said to use Buell rocker-box bolts instead of the stock Harley ones. Not sure how that can possibly help... but we'll see.
Also, the mechanic who's been working on the bike suspects that the chrome finish in the gasket area might be the culprit, so he's going to carefully bead-blast the area to help the gasket grip the metal. He's also checking for trueness of the machined surfaces... making sure they're as flat as can be.
It's not the oil breather gear, either. That's been ruled out.
Anybody heard of this? What was the culprit and what was the remedy?
Thanks.
p.s. I fully trust the dealership and it's mechanics. I don't believe it's lack of competence on their part.
I had similar problems with one of my Evo's, a 92 FXSTC that I converted to a Heritage. The manual and gaskets for that unit specify NO silicone. It's a dry gasket setup. After going through 3 sets of gaskets, I pulled em off, put a very light coat of heat treated silicone all around the base of the new gaskets, glued it back together, let it sit for 24 hours, and it was leak free for the life of the bike. Hope this helps.
seem like i repair at least one of these a year i use a product called hi-tac been around forever back in the early day when silly cone first came out an old mech ask me if that silly cone stuff squirted out and i said ya you just wipe off the extrathen he said what about the inside i said oh sh*t hi-tac come in a spray so you can spray the rubber and just lay it in the channel works great
My mechanic and I have discussed using some sort of adhesive for the gasket, but he was very cautious when discussing the silicone-based kind. Sounded like he really didn't want to go that route. Whatever is used obviously needs to be flexible and heat resistant. I've been researching alternatives at the local auto parts stores... but I have a strange feeling we'll end up using something like you did.
No problem. Glad to help. As far as it squirting out, and oozing into the inside. If that happens out either side, YOU"RE USING WAY TOO MUCH.... Note in my original comment that I said "very light coat", certainly not a bead by any means. In this case a little goes along ways. You just want it to permanently seal. And this did the trick for me. Believe me, I was ready for a fix after yanking it apart 3 times.... Good Luck.
Not endorsing product,s ,Yet i use a sealent called yamabond,gray in colour,need,s agas free oil free surface to cling to,...never a leak even on a hot day at the track..drie,s rock hard..will not swrill around in the motor if let to set up over night ..I hate oil leak,s been doing my own work on bike,s for year,s trial and error..forget about silicone based anything..
