clutch adjustment
Old Mar 18, 2009 | 09:56 AM
timebandit60185's Avatar
timebandit60185
Default clutch adjustment
i was wondering if there are any special tools i need for clutch adjustment in my manual it dont sany any thing about a special wrench but in other books and links so talk about a home made tool i need to adjust my clutch this weekend any advice thanks for any help
Old Mar 18, 2009 | 10:03 AM
SPARKY01's Avatar
SPARKY01
If your talking about adjusting the clutch itself and not the cable it helps to have a "claws foot" wrench for the nut that tightens down around the adj. Screw. Thats all you really need unless you consider a torque wrench to tighten the cover back down. However, you can use a box or open end wrench to tighten down the nut. Needs to be offset though.
Old Mar 18, 2009 | 11:16 AM
timebandit60185
thanks for the reply back all i want to do is adust clutch the manual states to loosen the clutch cable then so on it does not say any thing about any special tools just a couple of open end wrenches allen wrenches i dont want to loosen the cable take off the derby cover to find out i dont have the right tools i hav'nt done this before i dont want to screw it up so what is a claws foot and do i need it to adjust my clutch thanks for a ny help im kinda lost
Old Mar 18, 2009 | 11:31 AM
AK47's Avatar
AK47
here is a neat link I found on adjusting the clutch pak. Check it out. All you should need is a 7/16 wrench i believe, and an alan key, and whatever size torx bit for the derby cover. ( dont forget new gasket)
said link.
http://www.expertvillage.com/video/1...clutch-one.htm
Old Mar 18, 2009 | 12:45 PM
Leftcoaster's Avatar
Leftcoaster
No special tools needed. Do it just like the manual says and you're done. The paper gasket can be re-used but if it starts to leak just replace it and don't over tighten the torx derby screws. I don't use loctite here but use antisieze instead. Be sure to use the correct size torx (#27, I believe) since the screws are a little cheesy and a #25 will strip the head easily. Once you've got it done you'll say to yourself "that was easy".
Old Mar 18, 2009 | 12:48 PM
Peppa1's Avatar
Peppa1
An offset box end wrench for the nut will make it much easier to tighten down the nut and you want be hitting your primary cover.
Old Mar 19, 2009 | 12:50 AM
timebandit60185
thanks every body for your input i should be able to get it done this sat you all have been a big help ride safe
Old Mar 19, 2009 | 07:55 AM
harleytuner's Avatar
harleytuner
t-27 for the derby cover, 11/32 for the jam nut and the allen for the adjuster. Loosen cables (1/2" and 9/16" wrench). Remove derby cover, loosen jam nut, turn allen adjuster in, NOT TIGHT, just in untill it make's contact, back off 1/2 to 3/4 of a turn, replace derby, adjust cables. 1/16th to 1/8" of play at the lever.
Old Mar 19, 2009 | 08:13 AM
harley-jones's Avatar
harley-jones
This says it all!
Old Mar 19, 2009 | 08:40 AM
budnlucy's Avatar
budnlucy
I need to do this myself. Areay adjusted the cable 2 times so I guess it is time to adjust the clutch now.
