Rinehart tip problems???
Old Mar 21, 2009 | 12:25 AM
testifer's Avatar
testifer
i had a problem with my tip, i called them, they sent me a brand new set of pipes just because 1 tip turned on me. i put about 8 thousand miles on the new ones and they still look brand new
Old Mar 21, 2009 | 07:34 AM
hondo1's Avatar
hondo1
All this info is a little disturbing as the bike is in the shop right now having the Rinehart True Duals installed. Hope the outcome is better than some of what I am reading here.
Old Mar 21, 2009 | 08:51 AM
molsen's Avatar
molsen
Had an issue with my 2:1. The muffler was the same od as the hedder pipe. I called them and explained what happend. They made me a new pipe and took my old 1 back, even though I expanded it to make it work temporary.
Old Mar 21, 2009 | 09:05 AM
RODEO's Avatar
RODEO
Hey, my HD Screamin' Eagle Touring Mufflers came with replacable (selectable versions) tips too and I bought the Chrome and Black "revolver" tips. They are supposed to be remocable for easy cleaning of the chrome (under the black tip) but right out of the box those tips were a P.I.A. to initially remove just so I could install them. I don't ever envision pulling them off for cleaning because they were so difficult to remove while brand new and not even installed yet. Yea, quality has gone in the toilet in this Country with more and more of this stuff outsourced to China and other parts of Asia. We need a guy like Henry Ford back to straighten out our manufacturing process all over again before my Harley fully becomes a half chinese product.
Old Mar 21, 2009 | 09:07 AM
SpiderPig's Avatar
SpiderPig
20,000 miles on a set no issues here. Just my experience, FWIW.
Old Mar 21, 2009 | 12:41 PM
crewzerdude's Avatar
crewzerdude
Sorry to hear you are having trouble. I have an 06 SG with the Rinehart duals. I bought the bike used and it came with the Rineharts. I have never attempted to change the tips but they don't have a good fit where they crossover behind the rear cylinder and curve down over the chain case. They rest against the chanicase cover which doesn't seem right. There are rub marks on the pipe and chaincase cover where are in contact. There is pipe support behind the rear cylinder but it doesn't have enough strength to keep the pipe from dropping or sagging. Any one else had this problem with the Rinehart Duals.
Old Mar 21, 2009 | 12:51 PM
molsen's Avatar
molsen
Someone did not install the left muffler/pipe assembly correctly. It will be close, but not touching. I'm surprise that it did not make any noises for you. I had to mock it up a couple of times on my old scoot.
Old Mar 21, 2009 | 12:53 PM
Black Flag's Avatar
Black Flag
I saw a Black Cherry Ultra with Rineharts the other day, and the purple end caps were a perfect match!
Maybe if you drill out the hole and rock it back and forth carefully, you can elongate the hole into a slot. Then carefully line up the screw so it doesn't cross thread in the end cap. A little patience and yankee ingenuity can save a lot of return postage and down time. just my .02
Old Mar 22, 2009 | 10:06 AM
jamesrgarner's Avatar
jamesrgarner
The tip on the 2-1 I bought turned purple so I sent it back under warranty. They quickly shipped out another one that looked great but the threads on it didn't line up. I did my best to get all the screws in and finally give up with only two of the three. I really like the pipe but an still disappointed that it's not what I expected for the money I spent.
Old Mar 22, 2009 | 10:26 AM
Feedsack's Avatar
Feedsack
Thumbs up Caps
I had the same problem, so I got a set of chrome fishtails and the problem was solved. Never liked the black caps anyway.
