To hot
Old Mar 23, 2009 | 09:45 PM
cycletrash98's Avatar
cycletrash98
I put a stage one air filter and true duals with xied and solved that issue with my 08 ultra
Old Mar 23, 2009 | 10:02 PM
mrs overtime39's Avatar
mrs overtime39
5th Gear
Default re too hot
We had the same trouble on our 2008 Ultra so we installed a stage one kit with rush slip ons and added the mid frame heat shields. This really cut down on the heat.
Kris & Marilyn 08 Ultra
Old Mar 24, 2009 | 04:01 AM
Captain Itch's Avatar
Captain Itch
Sponsor
Give our crotch cooler a try if it does not work send it back for a full refund.That is how confident we are with our product.Half the price of other shields,and very easy to install.
__________________
www.Captain-Itch.com
Old Mar 24, 2009 | 08:21 AM
Firebike32's Avatar
Firebike32
I added the mid frame heat deflector and built a heat sheild for the left pipe.
Old Mar 24, 2009 | 08:27 AM
wiredwilly's Avatar
wiredwilly
I say if it's cooked, eat it....it's better hot
Old Mar 24, 2009 | 08:33 AM
SG 1's Avatar
SG 1
Stage 1 with a good fuel manager is the best answer, but you can do a fuel manager without doing anything else. Just get that bike a little more fuel, it will run cooler.
Old Mar 24, 2009 | 08:48 AM
honestbob's Avatar
honestbob
I put a nightrider 02IED on my 08 FLHT and it cooled it off a bunch! If you are gonna leave everything else stock thats the cheapest and easiest route.
Old Mar 24, 2009 | 08:56 AM
tda69's Avatar
tda69
Originally Posted by liv2ride57
Garyak,
One other thing you can do for your wife, and something many people at the dealerships don't know, the 08 Ultra can be, or was adjusted at the factory like the 09's to turn off one cylinder when the engine gets over a certain temperature at idle. You do not have to roll the throttle forward like the 09, the system, once set, does it by itself. I recently had my dealership do this to my bike in anticipation of the summer coming. Hell, most of the sales people at the dealership when I mentioned I had heard about this adjustment said HUH?? The dealerships will do this for nothing as it should have been set by the factory, if yours isn't pre-programed already.
Keep the greasy side down always.
Liv2ride.
There's an easy way to find out if your bike has this feature already enabled. My my bike did and from what I read the bikes built from Dec. 07 through the end of the model year had it enabled at the factory. Here are the steps.
1) With the ignition off, turn the switch to Run (fuel pump)
2) Turn ignition to the ON position
4) Roll throttle forward and hold it approx 5 seconds.
5) Watch your Crusie Control Instrument Light to flash RED or Green.
6) Release throttle once lights begins to flash.
**Red flash means system is disabled. Green flash means system is activated. You can turn on/off the system by repeating the procedure. It is not necessary to start the bike for this procedure, just follow the above steps.
Old Mar 24, 2009 | 09:02 AM
Our07Ultra's Avatar
Our07Ultra
Garyak,
Liv2ride.
Can this be done on an 07 or was it new to the 08"s?
Old Mar 24, 2009 | 09:06 AM
Open Road's Avatar
Open Road
Originally Posted by dawg
A few things you can do. Install an oil cooler, install a stage 1, install heat shields, install passenger footboard spacers, install true duals instead of the crossover, install all the above.
And install the Kuryakyn passenger adjustable footpegs. They add several options for the passenger, besides just the floorboards (you keep the floorboards, also) that allow her to get her feet up and out of the way.
Any of the above will help individually but collectively they help the most. Some things.....cams, air cleaner, tuner, exhaust, oil cooler, etc. will not just help her be cooler.........it'll also help your motor to run cooler (spell that longevity of the motor) so I'd suggest those changes first, if you're not able to afford them all at once. By the way, these same changes will also add more horsepower and torque, too (better passing ability as well as better climbing in the mountains).....especially when loaded.
