what the hell is this wire
Old Mar 24, 2009 | 03:15 PM
n8dc's Avatar
n8dc
Originally Posted by molsen
Only the Road Glide models.
ahhhhh .. thanks ill write that down in the log book
Old Mar 24, 2009 | 03:23 PM
harleytuner's Avatar
harleytuner
Is there only 1 wire or two? It could be the wires that hook up to the throttle cable for the cruise control.
Old Mar 24, 2009 | 03:26 PM
molsen's Avatar
molsen
Is it not the aux power for the switch on the right side of the nancell? I remember my '98 had the switch on the right side and a loop pigtail so you can add an accessory. If you have the manual see if you can find the diagram. I believe that is what orange wire is.
Old Mar 24, 2009 | 03:36 PM
keltonkrew's Avatar
keltonkrew
I have cruise and it's not that wire. It's not controlled by the aux swithc on the riser either. it's just a hot wire with switch is turned on. it's not the wire that goes to the fender light either....guess it is the invincibility wire...may have to hook up to it there's only 1 wire and it's a positive wire
Old Mar 24, 2009 | 03:37 PM
artt's Avatar
artt
Orange with a white trace is the wire for the fender tip light according to the service manual. Domestic bikes only.
Old Mar 24, 2009 | 03:46 PM
keltonkrew's Avatar
keltonkrew
well my light works on my fender and this light is right by the steering tube on the right side...don't know but I'm going to use the damn thing for a 12v cig lighter plug for my gps!
Old Mar 24, 2009 | 03:48 PM
HDRider2002's Avatar
HDRider2002
Orange with white trace is controlled by ignition, and i've used it to tie in power for radio, gps, etc. Why you have it hanging there is another question i can't answer. If you ever need power for accessories, tht will come in handy.
txfxstrider's Avatar
txfxstrider
What about ABS?
Old Mar 24, 2009 | 03:54 PM
Jinks's Avatar
Jinks
Originally Posted by keltonkrew
between the forks by the steering head tube on the right side. had a plastic cover type thing that fell off. has power to it when ignigtion is on. is this the power feed if you have a batwing? Is it fused? Reason I'm asking is there is a good place to install a 12v socket (like a cig lighter socket) so I can put there to charge my cell phone or plug in my gps. it doesn't have power until you turn on the ignition switch. just didn't know if it was fused or do I need to add a fusible link between that and the 12v recepticle. It has a female blade plug.
thanks
On domestic bikes it's called a "fender tip lamp" lead. There's usually a black lead with it with the same female blade connector. Both are common with the cigar lighter on bikes that have lighters. I use those connectors to power my GPS & garage door opener.
Old Mar 24, 2009 | 05:10 PM
karz10's Avatar
karz10
Just out of curiosity, you say it's only got power when ignition is on? Have you checked for power when either the low beam or high beam light is on?
Strange location for me, but my bike is a RKC, and have no idea about your line of bikes. I do think though that in my headlight nacelle there is a wire similar to that which would be used as a trigger wire for things like adding passing lamps or fog lamps, since most locations restrict the number of lights you can run w/ high beams vs low beams.
Just thought it would be worth double checking to see if worked on both high and low beam. Either way, it may or may not be designed to carry much load, could always ask a dealer if you can't find the right wiring diagram. Or if you're gonna keep the bike, maybe get service manual and see if it's in there.
ETA, all I saw were the big giant VSTAR letters, but now realize this may be a RK you're talking about. Anyway, don't know what or why it's there, but I'd still ck the light thing to be sure.
