air wing rack LED light. need help
Old Mar 24, 2009 | 03:57 PM
dboys's Avatar
dboys
Stage II
Default air wing rack LED light. need help
I am interested in purchasing the new air wing rack and LED light kit. I have a king tour pak without lights and am wondering where the light harness plugs into or do I have to do some splicing.
Old Mar 24, 2009 | 03:59 PM
mastery's Avatar
mastery
I spliced into my brake lights on my Tour Pak. I don't see why you couldn't splice into your main brake light.
Old Mar 24, 2009 | 04:26 PM
leadman's Avatar
leadman
I have this rack & light on order. On my EGC I was hoping the light would hook into
the extra plug I have in the tourpack.I figured this was the plug that would be used
if I had lights on the tourpack like an ultra.Am I wrong?
Old Mar 24, 2009 | 04:29 PM
Harleypingman's Avatar
Harleypingman
Can't help with this particular issue, but I've always been able to ask the parts counter help at the HD store to print out the installation instructions for HD accessories to allow me to see what's involved with their installation.
PM Dawg; he's great with these kinds of questions.
Old Mar 24, 2009 | 04:45 PM
dawg's Avatar
dawg
The instructions state on classic models without lights to install to the accessory outlet under the seat. The kit includes a 3 pin receptacle housing for this and the instructions show you which cavity to put the pins in. It also includes a grommet and instructs you to drill a hole in the bottom of the tour pak to route the wires.
Old Mar 24, 2009 | 05:00 PM
mkbrower's Avatar
mkbrower
I had my installed at the dealer before taking delivery. Here is where my was plugged when I took it apart to replace tour pak.
There is a plug at the main harness at the base of the tank and a small 3 wire harness that the air wing plugged into (picture 2). I don't know if this helps you, but this is how my was done.
Mark
Old Mar 24, 2009 | 07:53 PM
dboys's Avatar
dboys
Stage II
Thanks!! The pictures are a great help. I am going to order the rack and LED light kit.
ord sgt
Mar 3, 2019 03:09 PM
Seventy4blazer
Apr 21, 2015 08:12 AM
SFDonovan
Jun 9, 2013 10:24 PM
plutnicki
Feb 27, 2012 09:34 AM
robbie52
Dec 27, 2008 07:52 PM
