Turn signal from tour pack
Old Mar 27, 2009 | 10:20 PM
morrishuckeba's Avatar
morrishuckeba
Talking Turn signal from tour pack
For you then have the Badlands turn signal, brake light and running lights module. I have a 2007 ultra classic and I hooked up the module to my tour pack lights and now I have turn signals on my tour pack. It was easy to do, all you have to do is cut the blue and red wire on the right side of your tour pack and tie the blue and red wire together and splice in to the gray wire from the module and that will give you turn signal, break light and running lights on the left side. Do the same to the right side and splice into the yellow wire from the module to the blue and red wire on the right side. I hope that is not to complicated. If you have any trouble e-mail me or call Badlands they can help you. The turn signals from the tour pack makes you much more visible.
Old Mar 28, 2009 | 12:04 AM
Harleypingman's Avatar
Harleypingman
Good job; nice write-up. The same can be done with the HD run/brake/turn signal module using the brown and violet wires.
PS: The font you use is not easy to read for my tired eyes. Try verdana which is the default font.
Old Apr 13, 2009 | 11:55 AM
slime_dog's Avatar
slime_dog
Do you have to run any additional wires to the tour pack?
Old Apr 13, 2009 | 12:13 PM
TheShrink's Avatar
TheShrink
I would tap into the wires on the Illuminator and run new wires to the tour pak, then install the RideTimeTechnology LED boards.
Old Apr 13, 2009 | 12:21 PM
slime_dog's Avatar
slime_dog
Illuminator? Also, I have a quick release tour pack and was hoping to be able to convert without adding a new quick release harness.
Harleypingman
Jan 20, 2018 12:20 PM
Tookey
Jan 15, 2017 02:42 PM
Eric in chicago
Jun 15, 2010 08:28 PM
jeff194
Jul 3, 2008 05:48 PM
toyking23
20
Apr 24, 2007 10:34 AM
