true dual power loss?
Old Mar 28, 2009 | 11:33 AM
rochkes's Avatar
rochkes
I don't feel I am missing anything. I have over 100 tq at 2,000 rpms. If I had to make the choice, I would still give up 10 hp and 10 tq for the looks and the sound of my true duals on my 08. I am not so sure the appearance would be all that different on the 09's. I haven't been around many 09's yet or saw many pipe changes on them.
Dennis
Old Mar 28, 2009 | 11:52 AM
Donnylee's Avatar
Donnylee
The best way around this is to buy a Reinhart Slip on and use a header that is standard diameter. That way your not locked in to Reinharts headpipes. That is what I did..... Thank god I did because I have changed mufflers two more times after the Reinharts.
Originally Posted by Clint55
I had Rinehart TD's on the 08 Ultra. I loved the look and there was a definite cooling benefit. As far as performance, I did notice little drop off in low to mid range torque, but nothin to get in a twist over. All in all I has happy with the system.
Now with the 09, I'm taking a different path and going with the Dyno Tuned Jackpot package installed onto the stock head-pipes. I cannot ignor that this Stage 1 system will cost about 1/2 the cost of duals and will give me a 15 to 20% INCREASAE in both power and toprque.
If you do go true duals, I would suggest going with V & H headpipes and a slip on of your choice. If you go with the Rinehart head-pipes, they have a 2 inch inlet at the muffler and so you are very limited as to your muffler choices. I believe that Rush is the only other company that makes a muffler with a 2 inch inlet.
Old Mar 28, 2009 | 05:19 PM
nitechecker's Avatar
nitechecker
Never noticed any loss on my 08 or 09 with true duels.
Old Mar 28, 2009 | 05:26 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
i wouldnt call it a loss ,just not as big a gain in low end tourqe but a bigger gain in wide open hp.2-1 also wieghs less=wieght to power ratio.
Old Mar 28, 2009 | 05:39 PM
o5ultra's Avatar
o5ultra
I put true duels on 05 ultra last year best thing I did sound is great. didn't realy notice any loss on the low end but a good gain in mid and hi end you will like it
Old Mar 29, 2009 | 05:24 AM
Mark's Avatar
Mark
True duals on my 07 Ultra and noticed no power loss, runs better!!
Old Mar 29, 2009 | 05:43 AM
rjmac53's Avatar
rjmac53
rinehart TD on mine and luv them...
Old Mar 29, 2009 | 06:23 AM
glide2005's Avatar
glide2005
I had true duals on my 05 when I did the 98" build, Had Wild Piggs mufflers and tried V&H basic slash cuts. I went with 2-1 Thunderheader for the sound. With the TD on the dyno had 92 hp 102tq. With 2-1 had 94hp 110 tq. Not that much difference, but I love the sound of the TH.
Old Mar 29, 2009 | 07:48 AM
katobird's Avatar
katobird
The heat issue overrides the so called power loss. Sometimes I think some of these people have on board dyno's. Had duals for almost 2 yrs still trying to see where this lose of torque is
Old Mar 29, 2009 | 08:08 AM
jamesrgarner's Avatar
jamesrgarner
I put Rhinehart true duals on my Road King and noticed a loss of low and midrange torque. I ride a lot on two lane country roads and need to pass quickly which caused enough concern that I did the stage 2 kit. The looks and sound of the Rhineharts is great - but the black tips on the pipes, including the 2-1 on my Dyna, turned purple. They are guaranteed for a year, I had to replace all three. If I was doing it again I'd get the chrome tips.
