Squeaking Sound
Old Mar 30, 2009 | 10:59 PM
drykem's Avatar
drykem
6th Gear
Cool Squeaking Sound
2003 Electraglide. When I let off on the throttle the bike give me a squeaking sound. It does this only when letting off on the throttle, not when I have the clutch handle pulled. It might be that the belt is too loose, I thought I would ask before jacking up the bike and wasting time guessing. It got annoying coming through the mountains home this weekend, every damn turn it squeaked...pissed me off! Thanks for the help.
Old Mar 30, 2009 | 11:18 PM
heywood727's Avatar
heywood727
Start with your heatshields and go from there. They will losen up over time along with the dramatic heat swings that the pipe goes through.
Old Mar 31, 2009 | 01:21 AM
Potato_Potato's Avatar
Potato_Potato
An easy first thing to check is the rubber muffler mounts in the rear by the bags. Put some soap or WD on them as a temporary lubricant and go for a ride. If there is no squeak then you can replace the rubber or sometimes just by loosening and retightening the hardware will make it stop.
Old Mar 31, 2009 | 01:23 AM
txfxstrider's Avatar
txfxstrider
You guessed right the first time. Your belt is loose.
Old Mar 31, 2009 | 01:37 AM
JayStronghawk's Avatar
JayStronghawk
I would say check the belt and alignment myself....
Old Mar 31, 2009 | 05:14 AM
jpooch00's Avatar
jpooch00
I remember a bunch of posts like this back around '03. Seems like the fix was to clean the belt with soap & water using a toothbrush between the ridges in the belt and to be sure the tension was exactly right.
Old Mar 31, 2009 | 07:20 AM
papifun's Avatar
papifun
damm. i have same sound on my 08 SG.. as usual, HD dealer says is normal.. i only notice it when my bike gets hot.. could it be dust from the rear brakes being the cause ? i never washed my scoot since i dont plan to get it wet...
Old Mar 31, 2009 | 10:49 AM
Coffeeman's Avatar
Coffeeman
Just fixed what sounds like the same type of sound (chirping noise) on my 09, the belt needed adjusted--easy fix "if" it is the same thing (?). Always start out with the easiest and fastest checks :-)
Old Mar 31, 2009 | 11:13 AM
molsen's Avatar
molsen
Could be the belt, but I would lean toward the rubber isolater for the exhaust. I have that happen to me too many times. JMO.
Old Mar 31, 2009 | 11:33 AM
sooie's Avatar
sooie
i just had the same thing on my 04 ultra
it was the exhaust bracket just under the tranny cover (was broke)
$12 for a new one at the stealers and they had it in stock ha ha
