I'm a little confused. What is the actual size rear tire I need to order for my 05 ultra classic in the me880s? I called a couple of tire stores and they said they need the metric size, such as 140/85H-16. Not sure if this is correct.
The Correct size is the same size that came on the bike. That was a Dunlop MU85B-16. Metzler now makes that size. A lot of people have run 140 Metzlers on later model baggers, but the MU85 is wider by 6m.m. I measured both sizes of Metzlers. I think Metzler didn't make the MU85 years back, so they ran 140's, but they do now. I have 11,000 miles on my MU85 rear and it still looks okay.
I dont have the size handy but i can get it if you want to go bigger.. Its actually a gold wing tire its a 160 but id have to find the actual numbers.. Im running one and it looks and works great.
So what is the widest rear tire that you can run with the stock wheel. I know that you may have to modify your belt guard. But can you run a 150 on the stock rim? I have a 07 road glide and want to get a little more meat on the rear of the bike.
I recently pulled the 18" rear wheel off my 05 RG to go back to a 16" rear wheel.
I traded the stock 05 silver wheel for a black 07 wheel and am running an ME880 that is: "150/80 B 16" on it.
This tire is much wider than stock and it "just" fits. I've got a few thousand miles on it's and it fine. Wear appears to be consistent with the 18" versions I've been running.
Im running the 150 metz on my 06 classic with no mods . my paper work says ME880 160/80B 16 RR GL1500
