smell gas
Old Apr 5, 2009 | 11:20 AM
lschreiber's Avatar
lschreiber
4th Gear
Default smell gas
i have a 04 ultra and im smelling a strong gas smell after starting i find no sign of leaks can someone help
Old Apr 5, 2009 | 11:24 AM
Jim Dawson's Avatar
Jim Dawson
The only time I've smelled gas was the first day with my '08 when I left the gas cap on the gas pump.
Old Apr 5, 2009 | 12:05 PM
Scooter68's Avatar
Scooter68
Huh, I have an 04 Ultra, and I never smell gas after starting it. Did you take the gas tank off anytime recently?
Old Apr 5, 2009 | 12:18 PM
Lincoln33's Avatar
Lincoln33
I had the same problem with my 01 RK, periodically I could smell gas when I first started the bike and sometimes right after parking. I couldn't find a leak and didn't notice any performance problems. While doing the 95 inch upgrade I found out I had a hairline crack in the induction module assembly. After replacing it ($1065.00) I didn't have the smell of gas anymore. I'm not saying that's your problem but you might want to pull the air breather and back plate off and look at the module while starting and running the bike.
Old Apr 5, 2009 | 04:15 PM
Hx3's Avatar
Hx3
You might want to replace your fuel vent valve also....only a few bucks and solved a similar problem on my 99.
Old Apr 5, 2009 | 04:18 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
could be internal leak running rich.check pluggs.
Old Apr 5, 2009 | 04:27 PM
carpetride's Avatar
carpetride
you might try dropping a couple of these into the tank
saltlick
Mar 31, 2024 09:46 AM
chaselee
Nov 30, 2016 12:37 AM
itsmf
Feb 13, 2010 04:03 PM
sonic
Jun 21, 2008 10:26 AM
acedantinne
Sep 1, 2007 01:31 PM
