Idle
Old Apr 7, 2009 | 06:01 PM
Willy G.'s Avatar
Willy G.
Default Idle
What's your idle rpm? and what's normal. Mine has a fast idle at start up then fluctuates from 900 to 1000 rpm when it warms up.
Question is. Is the flucuation normal and what is the correct idle speed, she seems to be real smooth at 1100 rpm. Thanks.
Old Apr 7, 2009 | 06:07 PM
GM-4-LIFE's Avatar
GM-4-LIFE
Mine had the same condition, but I think it had to do a lot with the Fuelpak I installed. I removed the Fuelpak and had the bike dyno tuned and the idle is now smooth and perfect.
Old Apr 7, 2009 | 06:48 PM
Twist n Smoke's Avatar
Twist n Smoke
If I'm not mistaken I believe that the idle should be between 1000 and 1050 after warm up. I think mine on start up runs about 1100 to 1200. Please correct me if I am wrong. Hope it helps.
Old Apr 7, 2009 | 07:28 PM
HDV-GLIDE's Avatar
HDV-GLIDE
I have the same rpm's at idle with my fuelpak...Between 900-1000 after it warms up.
The Fuelpak is supposed to do nothing to the idle according to V & H.
The bikes ECM handles that function but if you idle is steady now, there may be more to the story then V & H is telling us....
Old Apr 8, 2009 | 06:54 AM
ajay450's Avatar
ajay450
My 08 EGS is stock and seems to idle at 950 to 1050. The idle speed does seem to increase and decrease a little between those numbers. You have to listen for it though. Without paying close attention it sounds pretty smooth.
Old Apr 8, 2009 | 07:02 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Your right, if your not looking at the tach, you may not even notice it....
Seahorse
Feb 21, 2019 07:49 AM
Dazzauk
EVO
21
Sep 6, 2016 12:01 AM
nkfd13
Apr 1, 2011 12:41 PM
corona1cal
General Topics/Tech Tips
Aug 1, 2008 02:45 PM
tcshovel
Exhaust System Topics
Mar 9, 2008 06:14 PM
