Bike (maybe brakes?) making a roaring sound when turning at speed?
Old Apr 8, 2009 | 05:57 AM
sofadog's Avatar
sofadog
My '07 does it, figured that it had to be the tires.
Old Apr 8, 2009 | 06:23 AM
The Old Man's Avatar
The Old Man
My EGC does it and it much more noticable with the soft lowers on. Bounces the sound waves right to me. Hear a lot more mechanical noise also.
Old Apr 8, 2009 | 06:32 AM
skootchnc's Avatar
skootchnc
Dunlops tend to make noise while in turns... my E-3's howl like a pack of cicadas when I heel the RG over in a curve, the faster , the more I lean, the angrier the cicada sound.
but I'd still check the brakes, as well as both wheel bearings
Old Apr 8, 2009 | 06:39 AM
oinker02's Avatar
oinker02
I noticed it from day 1 on my 07 King.....It's the tires.
Old Apr 8, 2009 | 05:00 PM
workformetoo's Avatar
workformetoo
Yeah, mine seems to do it worse on asfault mostly over 30 mph. thanks for the replies. Big
Old Apr 8, 2009 | 05:14 PM
FLoTR's Avatar
FLoTR
Originally Posted by acftdr
I think it's the D402's. I've ridden Ultra's from '05, '06, '07, and currently own an '08. They all make an occasional whirring sound when going through the sweepers at moderate speeds. I'm thinkin' it's doing it when you get over on the side of the tread on just the right road surface. Doesn't do it all the time.
Yeah, my 09 does it the same way. I too feel like it the softer rubber on the edge of the tires. It has a faint mud grip sound.
Old Apr 8, 2009 | 05:18 PM
workformetoo
I wonder if 1 kind does it worse than others? Mine has the original (thick white wall) that came on the bike.
Old Apr 8, 2009 | 05:20 PM
seldyn1's Avatar
seldyn1
Wink
Yep... bet is your tires. Try just weaving in your lane and see if you get the same sound. I bet you will.
Old Apr 8, 2009 | 05:29 PM
FLoTR's Avatar
FLoTR
Well, nothing has fallen off of it so I'm just gonna "keep on keepin on." When I replace these I'll use the same Dunlops. They get great mileage if kept properly aired.
Old Apr 9, 2009 | 09:44 AM
PnDegc's Avatar
PnDegc
It might be the tire wear bars - on a previous bike (not a Harley) it was the sound of (you need new tires)
