run turn controller
Old Apr 8, 2009 | 08:38 PM
rhaneski's Avatar
rhaneski
Default run turn controller
Hi everyone,
I've got the Harley run turn controller that I used on my softail before I put the Kuryaky panacea lights on.
ON my 08 Ultra ive got the wig wag xp running the tour pak Brake lights.
Can I still use the run turn controller for the lower brake light and the turn signals?
Where does it plug in on the Ultra.
Thanks
Old Apr 8, 2009 | 08:55 PM
Mick's Avatar
Mick
If you have the older Harley brake and directional module , it probably won't work on the 08
Because of the tssm setup.
The newer module has run-turn-brake and would work on the 08.
The connection is right under the seat , and a really easy install.
I had an older style Harley controller on my 06 FLHT and it wouldn't work on a friends 07.
The newer Harley module worked on both and my 09 FLHTCU.
If the wigwag module is only connected to the stoplights up in the tourpack , you shouldn't have any problems.
If it was a problem , you would only have to go before the under seat connection for the brake light wire , before the new module if need be.
If you have the older module , I would go with the badlands illuminator on the 08 and then you would have more versatility for leds and future add ons , I did this on my 09.
Hope this helps.
Mick
Old Apr 8, 2009 | 09:54 PM
rhaneski's Avatar
rhaneski
I got the module a year ago and used it on my 06 softail
mjonesjr84
Sep 12, 2015 06:11 PM
sportyguy69
Apr 29, 2013 05:02 PM
HarleyReece
EVO
Jan 29, 2012 06:53 PM
clanker24
Jun 8, 2009 11:19 AM
cdestuck
Feb 9, 2009 09:27 AM
