Hello All, Roadking Question????
Old Apr 13, 2009 | 06:56 AM
kettlinton's Avatar
kettlinton
Stage III
Default Hello All, Roadking Question????
Hello all, i am new to the forum from Alexandria,Va. I am in the market for a Roadking and have a question i hope you can answer for me. I have a liquid cooled crusier now and was wondering is there a big issue with the air cooled roadking? This is the only thing holding me back as i am in traffic alot here in the Md,DC,Va area. thanks for your help on this!!!
Old Apr 13, 2009 | 07:23 AM
sparky_mo's Avatar
sparky_mo
Nope.
Old Apr 13, 2009 | 07:39 AM
heavy K's Avatar
heavy K
You'll notice a difference but you should be fine unless your completely stopped for long periods of time in the heat of the summer.If ya can move a bit here and there at slow speeds you'll have no problem.
Old Apr 13, 2009 | 07:43 AM
FUJILICIOUS's Avatar
FUJILICIOUS
Not really. But there is a limit to them. When you say "in traffic a lot", how much stop and go is there. If it's more stop than go, there is always a possibility of the heat issue. As long as the bike is moving, even at a snail's pace, it will be ok because air is moving past the cooling fins. Additionally, depending on the year of the bike, some will have a feature that will shut down or retard one of the cylinders if the bike is in an overheating situation. But that seems to be the exception rather than the rule. I believe in the toughness of these engines and you should not have any issues.....other than the heat eminating from the bike, which can be a crotch/thigh burner. But there are things that can be done to reduce/limit that effect.
You can always try to rent one for a day and put it through its paces.
I say go for it. Good luck.
Old Apr 13, 2009 | 07:58 AM
Buzzsaw's Avatar
Buzzsaw
As Fuji Said there are many things that can be done to shield the heat if you are stopped for a long time, HD has some heat shields which are standard on some of the later models. (The 96 in puts out more heat than the 88's) RJ's originals makes a good heat shield. So far I have done the Fuelmoto Stage 1 and it seems to be running cooler, still need a really hot day to tell if I need to go with a set of heat shields also. (I try not to sit still for long) Being in the DC area also, I feel your pain of the traffic. Frederick HD rents so you can try one out, I rented one from the to try out the new 96 before I bought mine.
Just get it, you will love it.
Old Apr 13, 2009 | 07:59 AM
monkyman's Avatar
monkyman
I had no issues with my 03 88" motor, and the new ones you can chose to shut down the rear cylinder if the engine gets above a certain temp.
Old Apr 13, 2009 | 08:23 AM
dsigrist's Avatar
dsigrist
I ride an '02 Road King Classic in Ft. Worth/Dallas stop and go traffic and I've not had any trouble even when the ambient temp was in the high nineties to 100. I run 100% synthetic and the hottest I’ve seen the oil get is around 230 – 240. As was said above even some forward movement helps.
Go for it and get out and ride!
Old Apr 13, 2009 | 09:07 AM
TennesseeJed's Avatar
TennesseeJed
As that is all that is holding you back, buy a new Road King. The owners manual easily details how to engage the Engine Idle Temperature Management System.
See how easy that was?
Old Apr 13, 2009 | 09:52 AM
murderedoutking's Avatar
murderedoutking
2nd Gear
Default Road King
I ride with others that have and have ridden liquid cooled bikes the only difference they stated was the amount of heat coming from the bike when waiting in traffic. I know WA. state doesent get that warm but never expierenced problems in traffic. Get it youll never change again.
Old Apr 13, 2009 | 10:00 AM
HDRider2002's Avatar
HDRider2002
I've ridden my road king in the Memorial Day run for Rolling Thunder and not had any issues. As the others have said, as long as you are moving even slowly, you'll be fine. If you ever run into problems, you can always go with the add on fan, oil cooler, etc.
