Heel Toe shifter question
Old Apr 14, 2009 | 03:28 PM
CruzN's Avatar
CruzN
Default Heel Toe shifter question
I have a 09 FLHT, the heel shifter seems loose to me.
It slides side to side about 1/4 of an inch. The bolt is tight and I can't slide it off. Is this normal ? The toe part is tight and doesn't move.
Old Apr 14, 2009 | 03:33 PM
cmdwolf's Avatar
cmdwolf
Smile
should not slide around. R U sure it is tight. I am sure others will give you some advice that are more mechanically inclined than I.
Old Apr 14, 2009 | 03:36 PM
monkyman's Avatar
monkyman
It won't slide off because there is a slot the bolt goes into. But it shouldn't be loose. I removed mine as soon as I got the bike because I can't stand the heel shift. Kuryakyn sells a nice heel eliminator.
Old Apr 14, 2009 | 04:03 PM
fairplay's Avatar
fairplay
don't worry about it. it has to have some play.
Old Apr 14, 2009 | 04:14 PM
honestbob's Avatar
honestbob
only if you want to strip out the splines
Old Apr 14, 2009 | 04:41 PM
my1sthog's Avatar
my1sthog
You need to muscle that bolt, it will tighten. Since the bolt goes thru a slot, it needs to be centered before tightening, otherwise it will come loose.
Old Apr 14, 2009 | 06:00 PM
hockey8787's Avatar
hockey8787
are the splines stripped????
Old Apr 14, 2009 | 06:40 PM
curlydee's Avatar
curlydee
I have seen one heel toe shifter that had a flaw in the space that was suppose to draw together. I removed the burr and it tightened up.
Old Apr 14, 2009 | 07:29 PM
kymshu's Avatar
kymshu
Default My heel shifter fell off Saturday
My heel shifter actually fell off Saturday morning. i have 2500 miles on my 09, heard a clunk, looked down and saw it was missing. I stopped and went back and picked it up and the bolt was still in the shifter and tight. I was by the dealer so I drove over there and they reinstalled with red loctite. Ii checked it and it was still loose so I had him retighten until there was no play. I had never checked it before it had fallen off, just assumed it was on right.
Old Apr 14, 2009 | 07:30 PM
RODEO's Avatar
RODEO
Mine fell off a few weeks ago and I hadn't been using it at all, so no worries now that it's gone.
