Torque Wrench Question
Old Apr 15, 2009 | 03:00 PM
cbears's Avatar
cbears
Originally Posted by woods
I have been collecting tools over many years.
Most of my basic hand tools are Craftsman because they are cheap and easy to replace if broken.
I have been using Craftsman dial torque wrenches for ever and upgraded to a clicker style this last year. I did some research and found the new Craftsman torque wrenches are junk so I looked elsewhere.
"Google Torque Wrench" You will have plenty to read.
Ended up getting a nice 250 lb clicker Proto off E-bay for under $45.00 shipped to my door.
I would not be not as concerned for the accuracy of the wrench(120 lbs being 120 lbs) as I am for the consistancy of the torque settings on the wrench. If the true settings on the wrench are off by 5% is not as important as making sure it is consistantly 5% off while torquing everything down.
There will also be different settings between wet and dry torquing. You will almost always need to use some sort of lube (oil) but the book may not say that.
Starting to ramble. Hope this was of some help.
Ken
Yes, thank you. I'll go do some reading.
Old Apr 15, 2009 | 03:04 PM
OldPhat's Avatar
OldPhat
Craftsman in the inch lbs. and Snap On in foot lbs. bolth are clicker style. Eather brand is good for home or shop, bike, car, pickup, or Hot Rod.
Old Apr 15, 2009 | 03:13 PM
old skool1983's Avatar
old skool1983
go to harbor frieght and get both of them for 40bucks, they work great
Old Apr 15, 2009 | 03:31 PM
cbears's Avatar
cbears
That's what I'm talkin bout!!!! Got a Harbor Freight right here in town.
Old Apr 15, 2009 | 03:49 PM
txbazzman's Avatar
txbazzman
I have found harbor freight tools are fine as long as you do not use them a ton and you do not abuse them
Old Apr 15, 2009 | 03:56 PM
Greybeard48's Avatar
Greybeard48
I have both an older Craftsman in/lbs and ft/lbs torque wrench, but a couple of years ago a bought another set from Harbor Freight to leave in my truck. If I was doing mechanics for a living or using them all the time I might consider something else, but both sets work just fine for what I need them for.
Old Apr 15, 2009 | 04:00 PM
cbears's Avatar
cbears
That makes sense. I'm not a mechanic by trade so these won't be used but a couple times a month probably. I'll be doing mostly service type work I would imagine. I'll still take it to the shop for the hard stuff. Thanks for responding.
Old Apr 15, 2009 | 04:05 PM
Dr.Hess's Avatar
Dr.Hess
I have a HF ft-lbs clicker and a Craftsman inch pound clicker that I had to buy in Pierre, S.D. when this pic was taken behind the motel:
As a side note, a fella could make a lot of money opening a HF store in Pierre, S.D., 'cuz there ain't nothin' there otherwise.
On another board, a guy used to hang out that tested/calibrated things like torque wrenches professionally. He said that the HF ones were actually quite accurate.
Old Apr 15, 2009 | 04:06 PM
watercop's Avatar
watercop
I have both a 1/4" and a 2/8" drive torque wrench from Harbor Freight...had the for 5 or 6 years. I use them whenever there is call for a torque spec on both the vehicles and the Road King...never had a problem
Old Apr 15, 2009 | 04:25 PM
piasspj's Avatar
piasspj
The clicker ones are fine.
I don't care for the digital ones, especially if they are not used very often.
Nothing wrong with HF, they come out good in the tests I've read.
