Removing inner this week for painting, need tips!!
Old Apr 20, 2009 | 08:58 AM
Bushy's Avatar
Bushy
I think the service manual is by far the best investment you can make on your your bike no matter what year or model
Old Apr 20, 2009 | 09:27 AM
Harleypingman's Avatar
Harleypingman
Before you start, look over the parts you will be removing to be sure you have the tools necessary. For example, you will need snap ring pliers to remove the snap ring at the bottom of the clutch perch so you can remove the clutch cable. You will also need a couple of sizes of Torx bits for the outer fairing screws (T27) and others for the switch housings.
It's also a good time to lube the clutch and throttle cables.
Old Apr 20, 2009 | 11:22 AM
liltrk's Avatar
liltrk
Originally Posted by mkbrower
I just put my inner fairing back on and I have two tips I can share with you. 1. Take the radio out. It makes putting the new fairing on alot easier. I believe the old fairing would come off alot easier with the radio removed but since the service manual didn't mention it I left it in. After about 30 frustrating minutes trying to get the new fairing on without scratching it, I removed the radio and it went on much easier. The second tip and its important! 2. the bottom screw for the radio speaker is shorter than the other two. If you put the longer screw in the bottom hole it will poke a hole in your new fairing. unfortunately I learned this lesson the hard way. Its a small hole so I'm going to live with it untill winter and then replace it again.
Mark
You also might try putting a bolt all the way through the hole and put a chrome acorn nut on the fairing side, then do the same with the other side.
Old Apr 20, 2009 | 12:37 PM
mkbrower's Avatar
mkbrower
Thanks for the tip! I have been trying to figure out what to do to try and hide it. That sounds like a great idea.
mark
Old Apr 20, 2009 | 12:41 PM
Jonny Cannon's Avatar
Jonny Cannon
+1 on the manual. However, it tells you to lock the forks before removing the ignition, but doesn't tell you to unlock them, so you have your ignition out, the forks locked, and can't get the inner out. Be sure to ignore that - just remember the position of the ignition switch when you remove it. Hell; even if you forget (like I did), it's easy enough with a long flathead & flashlight to get the ignition back in.
Cannon
Old Apr 20, 2009 | 01:07 PM
TKrustyK's Avatar
TKrustyK
Just did mine and the only PIA was getting the throttle cables out of the housing. Had to punch one out 'cause the manual says to rock them back and forth when trying to remove them - NOT!
Old Apr 20, 2009 | 01:10 PM
cfmii11's Avatar
cfmii11
+1 on the pictures and the zip ties.
Old Apr 20, 2009 | 05:52 PM
harleybill2008's Avatar
harleybill2008
I did a small write up when I did mine, taking pictures from the forum, the actual swap and the service manual. It might prove to be helpful and if used, I would love to know if it helped or what might be beneficial to add. You can see this on "HOW TO" section (right side of screen) at http://www.harleybill.com (just my personal website so nothing fancy).
Old Apr 20, 2009 | 06:19 PM
Moe55's Avatar
Moe55
Use plastic bags to put the screws in, ignition switch and lable the bags. I used a 3 shelve cart to put the parts on. For me anything on the floor will get kicked or stepped on!
Old Apr 20, 2009 | 06:49 PM
Scooter68's Avatar
Scooter68
I just did this myself recently, pita no, time consuming yes. + 1 on the take lots of pictures of everything, and +1 on the plastic bags and label them. Take your time and patience.
