Proper way to break in new motors
1. Head Quarters - New Engine Break In and AFR
2. How To Break In Your Engine For More Power & Less Wear! Also linked from the Baisley Hi-Performance
3. Hastings (Piston Ring) Manufacturing Company - Break-In Procedure
Here is a pic of one of the pistons removed from my engine that has 8500 miles on it. I broke it in a little harder than the HD manual suggests. Note, the top ring never fully sealed. The engine builder told me this piston looks better then most he sees. The pistons were removed to install a 103 big bore kit.
Here is a pic of a piston where engine was broken in on the dyno at WOT and there are 3300 miles on it.
Here is a pic of a piston where the engine was babied at brake-in. There are 4200 miles on the piston and you can see it is discolored on the skirt. This is a piston that let the gasses past all the rings and it burned the bottom of the piston. Combustion heat should never be there.
This piston has 2000 miles on it. Rings never sealed.
My new build will be broken using the procedures above.
WOT pulls right from the get go.
The idea is to break in the surfaces of the rings and cylinder, bearings, gear surfaces, etc. under a variety of different loading conditions so that the fit is consistent. While under a steady state condition, such as running on cruise control at a constant speed, pressure at certain points tends to be stronger or weaker at the same places in a bearing race or cylinder wall, or on the surfaces of the gear teeth. Varying the load/speed moves the heaviest rub points around, so you get more even wear. Once the break-in is complete, and the surfaces mate as perfectly as possible across the loading range, then you get the best performance across the board.
JMHO
3. Axtel - Ring Seal - PDF -
4. Hastings (Piston Ring) Manufacturing Company - Break-In Procedure
It has been my experience with motors that use a little oil, they last longer and run stronger JMHO.
WOT pulls right from the get go.will the extra 500 rpms I did in the first 50 miles have a negative affect on the motor?
By the way this process sucks. I am so looking forward to the 1000k mile mark to add the D&D 2-1 and PC V.
And now would be a good time to change the oil using Petroleum oil.
Break in link #1
Break in #2
