Is it really necessary?
Old Apr 23, 2009 | 03:51 PM
Lightning's Avatar
Lightning
Stage III
Default Is it really necessary?
Ok so I have a 2009 FLHX with Vance and Hines regular slip-on ovals, stock air cleaner. The temperatures in my home state of Seattle WA. averages in the 60 to 75 degree range in the summer with some occasional 80 – 85 degree spikes. Is it the general consciences of the members of this Forum that my engine could suffer damage from over heating due to the OEM air/fuel ratio of 14:7.1. It’s my understanding that the ECU is capable of readjusting a small change such as slip-ons as long as the air cleaner remains stock. Does every fuel injected Harley since 2006 need a fuel modifier to control engine heat? If this is true there are going to be a lot of fried engines every summer.
To have to spend big $$$$$ to adjust fuel mixture from 14:71 to 13:8.1 is crazy!
Old Apr 23, 2009 | 03:54 PM
Akitakoi's Avatar
Akitakoi
I wouldn't say it's necessary, but it helps other things besides temperature.
Performance is noticeably increased also.
Old Apr 23, 2009 | 03:56 PM
dawg's Avatar
dawg
If you are talking about a tuner like a PC V, Race Tuner, etc. then you do not necessarily need it with just the slip ons and stock A/C. You can get some IED's that will enrichen the mixture and change your ratio. Those are like $80 for the pair. However, it does help with the heat and power when you add a tuner and a good dyno tune.
Old Apr 23, 2009 | 04:03 PM
gunner11's Avatar
gunner11
I'm running mine stock except for slipons haven't noticed anything but better sound, no more heat than normal. I might add a PCIII one day, but am in no hurry, just enjoying the bike right now.
Old Apr 23, 2009 | 04:38 PM
kingkingking's Avatar
kingkingking
You dont need a tuner at "Stage 1".
"Normally the installation of an air cleaner and performance mufflers will not cause any tuning problems for stock closed loop fuel injection systems as they can easily accommodate the extra fuel requirements". S&S Cat pg 5-22.
You can safely change pipes and AC without doing anything at all. The whole thing about needing a tuner as soon as you change pipes and AC is a cash grab.
There might be a minor performance gain by adjusting AF ratio or timing, but considering how conservative the cams are I would not put $$$ into a tuner.
Old Apr 23, 2009 | 05:00 PM
MEGALifted's Avatar
MEGALifted
I ran mine with the Rinehart slip-ons for several months with the stock air cleaner and no tune. I heard from many that I was doing damage to the motor and it was running excessively lean, but it ran great. I didn't see an increase in heat as other say, but I mainly spend my time moving and not sitting in parking lots or stoplights.
I just purchased a RSD air cleaner and knew that I'd want to adjust the fuel curves on it, so I ordered a PC-V and Auto tune modules. With the Power commander software, positive numbers equate to adding fuel and negative numbers equate to subtracting fuel at the given RPM. I was expecting to see the base map data with all positive numbers because that means it's enriching the fuel mixture. To my surprise, it only had positive numbers in the mid range and negative numbers up top. If the bike runs so lean, why would you pull fuel from it??
To sum it up, I've never heard of anyone screwing up an engine because they added slip ons and didn't remap. I've asked for proof and have never received it. The Power Commander did make a noticeable difference in the power and drivability so I do highly recommend it. Did it turn the SG into a sport bike, not a chance...
Old Apr 24, 2009 | 11:22 AM
Lightning's Avatar
Lightning
Stage III
Good responses guys and truthful answers. I’m really tired of people pushing products. I also have not noticed any issues as a result of installing my after market slip-ons. I did however question whether the ECU would be capable of self adjusting back to the OEM AFR 14:7.1 or if it would cause a leaner mixture the result of going beyond the ECU capabilities. I sure would like to hear from someone who has changed both pipes (slip-ons) and air cleaner and knew what their AFR was without the addition of a fuel enrichment devise. If I knew for sure those changes would still keep in the stock setting range, I’d save myself $800.00 to $1,000.00 for a PC-V or Race Tuner.
I can live with the slightly lean touchy/sensitive throttle response above idle, and the fuel mileage is a plus, but I don’t want to add a Screaming Eagle air cleaner if the end result is leaner then the factory setting.
Any one have first hand knowledge?
P.S. $800 dollars for a 7 to 10 hp gain is not a bargain with a Harley. I didn’t buy this bike to race it or I would have kept my BMW K1200 GT or MV Agusta.
The slip-ons were for improved sound while the desire for the SE air cleaner would be to just improve efficiency.
Lol… Besides who are we going to race with a Harley Dresser; another Dresser?
I've been told by an ex-Harley mech. that all that is needed with slip-ons and SE air cleaner is a simple $125.00 download at the Dealer that takes less than an hour, minutes actually.
skm348
2014-2024 Touring Models
15
Jul 31, 2017 08:35 AM
1Canuck
Aug 24, 2011 06:19 PM
jupiter2
Feb 21, 2011 08:57 PM
shore
Feb 4, 2011 07:36 PM
ak47dennis
Oct 24, 2010 08:02 PM
