fairing wiring
Old Apr 30, 2009 | 11:30 PM
tbone22's Avatar
tbone22
Default fairing wiring
Had my inner fairing painted last November, just getting around to reinstall it and cannot find a good pic in the Harley service book of the wiring. Anybody have a front shot of a 05 or up ultra with the outer fairing removed?
Old Apr 30, 2009 | 11:42 PM
Hoffy's Avatar
Hoffy
Hopefully somebody will have that for you but if I am not mistaken and if a 05 is simliar to newer models it looks much worse than it really is because all the connectors are different and will only fit their counter parts, meaning you can't plug connectors into the wrong plugs. The main loom goes across the top of your radio and all the plugs kind of fall into place due to their lengths and style of plug. It's a little late now but this is why most folks will take a few digital pics before the tear-down. You might try the search also you never know, you might get lucky and find something that will help.
Old May 1, 2009 | 01:10 AM
Harleypingman's Avatar
Harleypingman
Here's a pic of a Street Glide I took today at my local HD store. I replaced the police interconnect harness on my '04 EG with the civilian harness and wanted to see how the interconnect harness was routed.
It's not an Ultra, but should be close to the same as your bike:
http://
Decent representations of the connectors' locations are in the Service Manual, including one at the back which identifies the connectors by number.
Also, the wiring diagrams show the wire colors for the various connectors so you'll know which connector goes to a gauge, a mating connector, etc.
For a good installation, you will need a couple of zip ties with the plug on the receiver end of the zip tie. The main wire bundle that goes above the radio uses such a zip tie and is "plugged into a hole tab in the mount for the speedo to hold it in place.
Good luck with your project.
Old May 1, 2009 | 07:48 AM
GLACIERPEARL's Avatar
GLACIERPEARL
A pic from my '06 Ultra. I left it BIG, so it's easier to see the wiring.
Cryswhite78
Mar 17, 2019 11:27 PM
Dermodad
Jun 10, 2016 04:20 PM
MMMichael
Dec 26, 2012 04:11 PM
Airborne350G
Mar 4, 2012 04:29 PM
asdrsd
Jan 15, 2007 11:55 PM
