whine from back wheel
Old May 2, 2009 | 10:15 AM
skydrifter's Avatar
skydrifter
The whine from the back is usually my wife.Then I lube her up..... but thats for another fourm.
Old May 2, 2009 | 05:26 PM
Hx3's Avatar
Hx3
If it's a pulsating sound you should check your rear wheel pulley bolts to make sure none have come loose and then check your rear rotor to see if it's warped. Do you use your rear brake as your main brake for stopping? If it was your axle/bearings it would be more of a squealing noise after you get the axle heated up with some higher speed riding. If it's not your brake rotor or pulley you should see if you have sufficient antiseize on your rear axle.
NoRegerts
Jun 4, 2013 10:36 AM
riderboy1961
Apr 19, 2013 07:48 AM
Doug S
Jun 12, 2009 11:13 AM
tennessee streetglide
May 6, 2009 02:01 PM
jrsmith_80
Aug 5, 2008 04:54 PM
