Does the SERT learn?
Old May 14, 2009 | 04:47 PM
kingkingking's Avatar
kingkingking
Default Does the SERT learn?
Do any of you tuners know if the SERT can "learn" and improve the tune?
The first time I ran the 124 up to 5000 it had a real hesitation and the exhaust sounded off beat and a little lean. Torque was real strong to about 4800 and then seemed to tail off. I am running the canned S&S 124 program and still running in. Anyhow, I have run her to 5k+ a few times and she seems to be getting better, torque seems to rise again about 5200 now. Maybe its just psychological??
Old May 14, 2009 | 04:53 PM
mattman22033's Avatar
mattman22033
No it does not learn. A SERT is just the box that allows you to tune the ECM. The T-Max, PCV w/auto tune are examples you units that adjust as you ride and even then you still need a base map to start.
Just have fun with your 124.
Old May 14, 2009 | 05:02 PM
kingkingking
Its acutally a pro super tuner now that I look at it. Is that a SERT or a SEPST??
Old May 14, 2009 | 05:11 PM
mattman22033
It is SEST but the same rules appy like the SERT.
Old May 14, 2009 | 05:12 PM
Harleypingman's Avatar
Harleypingman
Neither unit "learns." They are a comm device to allow changes to the ECM. The ECM has a very limited capability to "learn," at least those on U.S. models.
Old May 14, 2009 | 05:17 PM
kingkingking
Must be psychological then!!
Old May 14, 2009 | 05:25 PM
Zacharia_11's Avatar
Zacharia_11
Your ECM learns, there is a feature called Adaptive Fuel Control, the values are stored in memory of the ECM and allow for adjustments to AFR. These values over time create develop a correction profile that is applied to your AFR. I beleive these adjustments are marginal, I have read ~10% but I don't stand by that number.
Old May 14, 2009 | 05:46 PM
jag1886's Avatar
jag1886
The SERT is like everything Harley sells, it will learn but only if you throw money at it.
Old May 14, 2009 | 06:08 PM
badherb's Avatar
badherb
there are learning boxes out there. ThunderMax is the name it supposed to learn as you ride if you change your area ie go to the moutains it's supposed to adjust itself to that altitude and then back again when you get back home. cool item for $400-$600
Old May 14, 2009 | 06:18 PM
kingkingking
All EFIs do that - the MAP (manifold absolute pressure) sensor reads the reduction in air pressure at altitude and adjusts.
